  • 1994 - 1995 Specific Tech
Starter Relay Help
  • Thread starter Thread starter etstark
  • Start date Start date Dec 23, 2007
E
etstark
  • Dec 23, 2007
I just finished putting a new crate engine in my 94 GT. When I went to start it nothing happened.
I checked the voltage at the starter relay. One terminal has 12 volts all the time. Another terminal has 12 volts when the key is turned to the start position if the transmission is in neutral or park. That terminal has no voltage when the transmission is in drive or reverse when the key is in the start position.
I took the cover off the relay and pluged it in. With the trans in park, turn the key to start the relay doesn't activate. If I pull it out and supply 12 volts through the coil the relay works fine.
Looking at the wiring diagram, it looks like a very simple circuit and it looks like everything should work.
What am I mising?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 23, 2007
  • Dec 23, 2007
Chances are, the new engine is unrelated, and you just have a bad ignition switch. That's what it sounds like to me anyway. Your diagnosis of the solenoid sounds good, since you also verified the neutral safety switch as working. It cranks when you bypass the ignition switch, right?
HISSIN50
34
129
Dec 23, 2007
  • Dec 23, 2007
Welcome to the boards!
One point of clarification: The starter solenoid is piggybacked on the starter.
The starter relay is in the underhood fusebox. This latter (relay) is just a slave to the solenoid.
I agree with Matt about ensuring the CSS isnt staying open. Also check in/outs at the starter relay (in the underhood fusebox) if you have proper in/out voltage at the CSS. This could be a source of impediment.
Good luck.
E
etstark
  • Dec 23, 2007
Thanks for the feedback.
When the car didn't start, I disconnected the wire to the solenoid and checked the voltage when the key was turned to the start position. It had no voltage. That's when I went back to the starter relay in the fuse box. When I cannect a voltmeter to the terminal for the relay and turn the key to start, I get 12.09 volts. When I plug the relay in and turn the key the relay doesn't switch on.
Since no one told me about some special circuit I didn't know about I went back and plugged a spade terminal into the relay slot, connected that and the volt meter together and turned the key. Low and behold the relay worked. I guess that the terinal slot for the realy is my problem. The relay must not be making good contact.
I was going nuts for a while there but I think I can get it now.
Thanks everyone for your help.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
