  • SN95 4.6L Mustang Tech
starter
  • Thread starter Thread starter kaliman1984
  • Start date Start date Dec 19, 2009
K
kaliman1984
  • Dec 19, 2009
I have a 1999 GT and i have to change starter. I have some long tubes on there. Anyone have any hints on how to take it off due to the hard clearance that is available.
flstang65
1,484
135
94
SE Georgia
Dec 19, 2009
  • Dec 19, 2009
Either like 3 feet of extensions feeding them through the motor mount or, use a stubby wrench on the top bolt and drape a chain or something you can get some leverage on and pull down. When installing the starter back into the car, just leave the top bolt off.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 20, 2009
  • Dec 20, 2009
What he said. The top bolt you can feel with your hand but it is hard to get to. You may need and extra set of hands while you slip the extensions thru the motor mount, have someone guide the socket onto the bolt. You can replace it if you want but I left mine off...no issues.
hotrodredneck
200
Newport News Va
Dec 20, 2009
  • Dec 20, 2009
bingo....also add a couple swivel sockets in there
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 20, 2009
  • Dec 20, 2009
I have had good luck with a 13mm flex socket and a couple of long extensions. Run the extension through the motor mounts. Works best to have a buddy work the ratchet wrench.
It is fairly easy to get one hand up there to guide the socket, but everything is done by feel. Fairly easy to tell when on the bolt.
To re-install, Lightly tape the bolt to the socket. Once the bolt is started, remove the socket and the tape. Tighten. Again, having a buddy on the wrench helps.
D
d90212
253
kailua, hawaii
Dec 20, 2009
  • Dec 20, 2009
i wonder how many have actually changed a starter with long tube headers...
Turbo header Starter wire routing?
  • 387lx
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 3, 2026
387lx
Electrical Defrost switch ignition?
  • Teen'93stang5.0
  • May 16, 2026
Fox 5.0 Mustang Tech Jun 3, 2026
Teen'93stang5.0
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
