starting problems
  • Thread starter Thread starter coates50
  • Start date Start date Nov 11, 2004
C
coates50
27
  • Nov 11, 2004
replace starter and battery still won't start turn the key it clicks. But you take out the spark plug the motor turns over. replace the spark plugs all you get is the clicking sound
dastang2
2,020
tx
Nov 11, 2004
  • Nov 11, 2004
check all the connections and spend 10 bucks on a new solinoid. i would first say it would be the started but it has been changed, you say
J
jaackal
402
NJ
Nov 11, 2004
  • Nov 11, 2004
maybe the starter is defective from the factory
88blkmustang
pawling, ny
Nov 11, 2004
  • Nov 11, 2004
i agree with him....i know what your talking about my stang is doing the same thing. i pinpointed it to the starting solenoid. its a round black part right next to the battery. the positive cable off the battery goes there and other wires connect to one side then there is one wire coming off of it going to the starter. that would be the solenoid. that clicking your hearing is the start solenoid. i know how fusrating with that problem. believe solenoid
HISSIN50
34
129
Nov 11, 2004
  • Nov 11, 2004
or there is insufficent electrical flow - could be bad connections, low battery, etc. the fact that you unloaded some of the starter's burden (no plug) and it worked tells me the solenoid should be working.
good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 11, 2004
  • Nov 11, 2004
Here's a checklist:
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw) and jump it to the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
4.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then the relay is bad. See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars.
5.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
