  • SN95 V6 Mustang Tech
starting problems
  • Thread starter Thread starter M9rkym9rk112
  • Start date Start date May 4, 2005
M
M9rkym9rk112
62
Riverside, California
May 4, 2005
  • May 4, 2005
Whats up peoples in stangnet? So i went to pick up my girlfriend from class yesterday. I was 10 minutes early so i parked my car under the shade, and when 10 minutes was up i tried to start my car but it would not start. It would crank up but then it would die... what was weird, was when i take out my key, my alarm would turn on and i would hear a ticking sound and some lights would flick on and off...so i tried to start my car about 10 times, and still the same result. I even had someone to try and jump start it, same result. So i called the towing place to to my car to my house, which was about 6 miles away, and had to pay 65 dollars. So i dunno what happened, but a couple of hours later, i tried to start my car again just for the heck of it...and what do you know it started!!!! When i first started it, it sounded weird. I cant explain the sound, but it never sounded like that.. so i turned of the ignition and started it again, it started to sound like nothing is wrong... So i did it a few more times, and revving the engine...and everything sounds find...ANYONE knows what the heck is going on to my car???
M
M9rkym9rk112
62
May 4, 2005
  • May 4, 2005
Also, i dunno if i should drive it, but i need a car to get to school and to my work...it works fine right now, but im afraid yesterday might happen again...
98CobraClone
592
Ripley, Ohio
May 4, 2005
  • May 4, 2005
sounds like your PATS (passive anti-theft) may be out. If you use your tilt steering a lot, it will rub and eventually break the wires inside the steering column. Apparently that's a bad problem with the 98's. I just had mine bypassed with the chip, god a good enough security system with the 12 gauge
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
SN95 V6 Mustang Tech May 22, 2026
PNN
P
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
SN95 V6 Mustang Tech Mar 20, 2026
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
