  • 1994 - 1995 Specific Tech
Steering sqeaking
  • Thread starter Thread starter ponypowa
  • Start date Start date Apr 8, 2004
P
ponypowa
43
  • Apr 8, 2004
Ok my steering wheel is like a squeaky door It sounds so ghetto... is there anything I can do to stop this? A mechanic said it was "normal" but I know everyone's steering cannot be squeaking...
Gravel
216
Bellingham WA
Apr 8, 2004
  • Apr 8, 2004
Mine squeaks too....
Its normal for ball joints to wear out too but that does not mean that you don’t fix them....
I have decided that the word "Mechanic" is way too loosely used in the USA!!
I still need to fix mine, just had other priorities....
P
ponypowa
43
  • Apr 8, 2004
How do you fix them lol
Ronman
50
Huntington, WV
Apr 9, 2004
  • Apr 9, 2004
i had this same problem in my 96. i just got used to it after a while, until my ball joint fell out at a stoplight, had to fix it after that. the ball joint are pressed in, so you have to press out the old ones, and install new ones. i removed the sway bar end link, brake caliper and used a ball joint seperator to split the spindle from the lower control arm. pressed the old out, with a big hammer, and then put the new ones with hydraulic press. you probably should get it fixed soon, if i were going very fast when it came apart you wouldn't be reading this right now.
P
ponypowa
43
  • Apr 9, 2004
awesome thx for info
Bigsho2020
  • Apr 10, 2004
My steering did the same thing when I first bought my car and it was the tie rod. That is a lot easier to change than the ball joint.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
E
Steering stops not connecting
  • ELP1
  • Apr 25, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 25, 2026
ELP1
E
T
1990 Convertible door squeaking
  • Tom77
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Tom77
T
