steeting question
  • Thread starter Thread starter ONEBADPNY
  • Start date Start date Dec 23, 2005
ONEBADPNY
195
FREMONT, NEBRASKA
Dec 23, 2005
  • Dec 23, 2005
on my 66 coupe i noticed that i have alot of play in the steering wheel side to side. i can turn it side to side about an 1in. or 2 before it responds. it has no power steering. could it need a new steeringbox?
BullittStangV8
1,104
NJ
Dec 23, 2005
  • Dec 23, 2005
I have the same issue, and was actually wondering the same thing while at work. I think the steering box can be rebuilt to fix this? Also is there anything to make the manual steering easier?
Mike
rbohm
6,698
550
204
tucson,az
Dec 23, 2005
  • Dec 23, 2005
the steering box can be rebuilt. there is also an adjustment on the top of the box to allow for wear, but go easy on the adjustment as it is very easy to make things worse.
as far as making manual steering easier, you can install ball bearings in the idler arm, and you can reduce the amount of caster(dont do both though). you can also add a synthetic grease in the box as well.
ONEBADPNY
195
FREMONT, NEBRASKA
Dec 24, 2005
  • Dec 24, 2005
how do i go about find and making the adjustment? i am not to educated on the manual steering box of the old.
10secgoal
2,801
San Diego
Dec 24, 2005
  • Dec 24, 2005
The is a 5/8 nut on top of the box that you loosen. And a screw you tighten, then you tighten the nut back up. It's like a poly lock for a roller rocker. I would look into a ball joint being loose somewhere under there.
ONEBADPNY
195
FREMONT, NEBRASKA
Dec 24, 2005
  • Dec 24, 2005
everthing is new on the steering side except the steering box. i replaced everything up to v8 parts.
brianj5600
1,964
Middle TN
Dec 24, 2005
  • Dec 24, 2005
When changing my steering wheel I found a brass looking bushing just behind the wheel. It is "gunked" up and has to be adding to the effort it takes to turn. I have not consulted my manual to see if it needs grease or just cleaned and dry. Anyone know any tricks to reducing effort before the steering box?
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
