• Community Forums
  • Regional Forums and Event Information
Stereo Install Thoughts
  • Thread starter Thread starter Silvr04GT
  • Start date Start date Feb 9, 2006
Silvr04GT
1,131
San Jose, CA
Feb 9, 2006
  • Feb 9, 2006
Hey guys,
I went and pulled my deck from the Stang today to see what ideas might work for mounting the new deck. Inside the opening there is NOTHING to mount to except the bottom mounting point where the factory deck attaches. Here's a picture of the factory deck:
So it looks like it would be a matter of moving the existing hardware over to the new deck:
and
In terms of the front bracket it looks like I would really only need to drill out the existing holes to make them line up exactly with the mounting holes on the new deck.
As far as the rear bracket thing, it looks like it would need to cut and then some how attached to the unit. There are two screws (as you can see in the picture) those screws are both about 3 inches in on each side so if the rear bracket was cut so that it didn't interfere with the wiring spots and then some how added something to the bracket to make it reach to the two screws...
What do you guys think?!?
EDIT: I kind of mocked it up using tape to hold on the brackets and I'm going to get do a little test fit later tonight, I'll let you know how that goes.
Silvr04GT
1,131
San Jose, CA
Feb 10, 2006
  • Feb 10, 2006
Alright, so I did the test fit! And it worked REALLY well! I basically used packing tape to hold the bottom part on and I tried a similar procedure on the back part but that failed. So I took that part off and honestly I don't think that it makes to much of a difference.
I forgot to bring my digicam to take pictures but next week I'll try and get some pics. It fit perfect, the only thing was that on the Mach 460 there is that black trim around the edge of the deck so it covers up the metal, unfortunately this unit doesn't have that... so I need to come up with an idea to solve that. (Russ - maybe that piece you showed me at Visions might help that, we'll see... or whoever I get to do the install work can come up with something I'm sure.)
So going forward here I'm going to get bracket holes adjusted to match with the deck and screw size and then I just need to get that wiring harness from Russ and I think all is going to be well with this new deck.
T
Fox Help Request: Clutch Cable Installation on T5 Swap — I Can’t Find the Mounting Hole
  • TDM389
  • Feb 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2026
nickyb
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
'67-68 Scott Drake Trap Door w/6x9 Speaker Pods
  • bchampion
  • Jun 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 16, 2025
bchampion
  • Community Forums
