  • SN95 4.6L Mustang Tech
Still having fuel issues...
  • Thread starter Thread starter 98GTragtop
  • Start date Start date Nov 25, 2012
98GTragtop
88
Orange County, NY
Nov 25, 2012
  • Nov 25, 2012
So I have posted about this before but I am still running into issues. I have a 98 GT completely stock except for a JLT ram air. At times it will seem like i just run out of gas and the car will shut off. It stays like that for a while until i put it in neutral and push it around for a few minutes and then it starts again. The fuel pump is running so I can rule that out. I thought it may have been the filter clogging so I replaced it but the problem continued. Does anyone else have this problem? help...
renaldy75
Fort Lauderdale, Florida
Nov 29, 2012
  • Nov 29, 2012
I have something similar that when i go for a ride for like a hour and then i shutdown the car and turn on the car immediately it won't turn on i have to wait 1 minute to turn on back.. but when the engine is cool the car turn on fast and won't miss.
-CAR is not overheating
-60lb injectors vortech supercharger 12psi no intercooler
-17cc dishes piston 9.4.1 compression
Clayton302
79
Hurricane Utah
Nov 29, 2012
  • Nov 29, 2012
When it wont start press on the fuel pressure release valve on the fuel rail and see if it has high pressure. Be careful cause fuel will spray everywhere. Use a rag to cover when you do it. I would think its the pump having intermittent issues, since after you push it around (jar the pump) it starts. Do you hear it running when your trying to start it while the car is not starting? Also take a fuel pressure reading while it running and maybe you can see it drop while its having the issue. 98's have a combo of 97 and 99 fuel system and this should be noted when discussing the issue. Most people think that only 99 and ups are return less but the 98 has a similar setup so you might have to get more familial with the 98 gt setup. I had a 98 gt but I cant seem to recall if it was a full return less or not.
98GTragtop
88
Orange County, NY
Nov 30, 2012
  • Nov 30, 2012
I can hear the pump running the whole time that the car wont start. I know i have at least a little pressure in the fuel rails but i will have to get a better reading. The problem is that it is not easy to duplicate the problem so i can trouble shoot. It tends to happen whenever i need to be somewhere
Clayton302
79
Hurricane Utah
Dec 7, 2012
  • Dec 7, 2012
That seems to be about right
Do you have an update?
renaldy75
Dec 8, 2012
  • Dec 8, 2012
you were right it was the fuel pressure was very low.....thank
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
getting 90 PSI at fuel rail - help
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
