  • SN95 4.6L Mustang Tech
stripped my plenum
  • Thread starter Thread starter Stang|ess
  • Start date Start date Aug 9, 2006
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Aug 9, 2006
  • Aug 9, 2006
I was tightening the bolt in the plenum and I stripped it. The bolt just turns and turns .
How do I fix this? Threadlock, and ziptie it until it cures?
RedBullitt
462
Morgantown WV
Aug 9, 2006
  • Aug 9, 2006
well you are gonna have to retap the hole or work with some sort of threaded sleeve, work either way. the zip tie and loc tight shouldnt be anything perminant in any case.
Stang|ess
Oct 18, 2003
941
Hawaii
Aug 9, 2006
  • Aug 9, 2006
Thanks for the quick reply. I figured that i'd have to do that, but was looking for an alternative method since I don't have a threading tool.
nwapache
313
Seattle,WA
Aug 9, 2006
  • Aug 9, 2006
You might be able to rent one at the parts store ......
I'll be coming to see you in October...i'll try to rent a Hertz Shelby and we can zip over to the Northshore
Stang|ess
Oct 18, 2003
941
Hawaii
Aug 9, 2006
  • Aug 9, 2006
I believe its $250 a day but if you do rent it, its a date .
stupid question, if the hole is 5/16" what size tap do I get? I'm at sears right now and the people are unfindable. damn them .
the98stang
2,408
Clovis, CA
Aug 9, 2006
  • Aug 9, 2006
You need a helicoil kit. I don't know what kit you'll need off the top of my head....sorry
Stang|ess
Oct 18, 2003
941
Hawaii
Aug 9, 2006
  • Aug 9, 2006
I need a helicoil kit? Ill see if it works and report back with the part #.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Aug 9, 2006
  • Aug 9, 2006
way to go n00b!... lol just kidding
Sorry to hear about your bad stripping experience
jivepepper
776
Under a Sombrero. in WV.
Aug 9, 2006
  • Aug 9, 2006
Was it the bolt from the plenum to intake or the throttle body to the plenum? If it's the throttle body to plenum just use a smaller bolt and nut.
Stang|ess
Oct 18, 2003
941
Hawaii
Aug 9, 2006
#10
  • Aug 9, 2006
  • #10
it's the IAC to the plenum.
i found out that after driving around and doing errands, the plenum is very very hot .
nwapache
313
Seattle,WA
Aug 9, 2006
#11
  • Aug 9, 2006
  • #11
I'd better put my request in now then....I thought it was 169$$...oh well, who cares, it'll be a good photo op.
I'll PM you when I lock down the dates !
Seraphitia102
will post boobie pics for a supercharger
Oct 11, 2004
737
California
Aug 10, 2006
#12
  • Aug 10, 2006
  • #12
The Shelby GT-H at LAX airport is $99 a day I just checked attempting to see if I want to make a reservation.
2013 Geee T
805
Oak Park, CA
Aug 10, 2006
#13
  • Aug 10, 2006
  • #13
How are you posting from Sears?
Stang|ess
Oct 18, 2003
941
Hawaii
Aug 10, 2006
#14
  • Aug 10, 2006
  • #14
I have a sidekick.
I mentioned this about a dozen times, and nobody seems to know what it is.
Anyways, day 1: I bought tap that is too small. Day 2: I went back today, and bought another that's too small. I really wish they would put the size of the bit on instead of 10-pnc291788828 . The one 1 step bigger is a 1/4" and I'm going to have to enlarge my IAC hole to use it.
RedDaemon
3,470
9
108
Atlanta, GA
Aug 10, 2006
#15
  • Aug 10, 2006
  • #15
lol have fun viewing that on ur sidekick
jasonh_86
I
May 20, 2005
1,156
Arkansas
Aug 10, 2006
#16
  • Aug 10, 2006
  • #16
I thought I was your sidekick
Stang|ess
Oct 18, 2003
941
Hawaii
Aug 11, 2006
#17
  • Aug 11, 2006
  • #17
lol pictures get resized automatically .
to keep this tech, parts # 10-24NC and 12-24NC don't work.
BeelzebubSOB
193
Iowa
Aug 11, 2006
#18
  • Aug 11, 2006
  • #18
Just a thought,sometimes if the hole is deep enough you can get a longer bolt to work.Take a piece of wire or something along those lines and check the depth of the hole then check it alongside the old bolt to see how much longer you can go.If it is only a couple threads you will need to helicoil but if it is 1/4" or more you may be able to get away with a longer bolt.Have done it before in a pinch if helicoil isnt available.
san~man
O-G
A little grass shack on a big lava rock
Aug 11, 2006
#19
  • Aug 11, 2006
  • #19
Pwned
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
Electrical Headlight Harness Route
  • dan50
  • May 3, 2026
Fox 5.0 Mustang Tech May 3, 2026
dan50
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
