  • 1994 - 1995 Specific Tech
Stupid question?
  • Thread starter Thread starter 95YellowGTbeasT
  • Start date Start date May 27, 2004
95YellowGTbeasT
605
South Carolina
May 27, 2004
  • May 27, 2004
Can someone explaing to me how a turbo actually work??? i know it blows the exhaust out but how does the induction work??
mytight95
2,605
Dothan,Al
May 27, 2004
  • May 27, 2004
you have an intake side turbine, and an exhaust side turbine, the exhasut side spins the as the motors exhaust is pushed throught he pipes, the intake side is therefore spinning at the same time(however at a different trim) and forcing air into the motor. Thus creates boost in the intake track, that increases with rpm.
i am not good at explaining things so someone will prob. have to hel pbut thats a start
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
May 27, 2004
  • May 27, 2004
Think of 2 windmills facing each other with a spindle connect them at the center. If the wind blows on one of them (exhaust side from the exhaust flow) , they will both spin, and the one that is being spun is creating its own air flow (intake side)
Thats why Turbos are called "scavengers", because they use "waste" exhaust fumes to create power.
RC
95YellowGTbeasT
605
South Carolina
May 27, 2004
  • May 27, 2004
coolness i was wondering about this cause in the future i plan to turn my car into a total drag/cruising around car
Nick
A
Adrenalin
168
Central Florida
May 27, 2004
  • May 27, 2004
A supercharger is a belt driven pump that forces the air into the intake.
A turbo is the same thing more or less except instead of being driven by a belt the shaft (that would have the pulley on it) has another turbine on it and your exhaust leaves your headers and enters this turbine turning its shaft and that shaft turns the airpump (like a supercharger)
Supercharger - belt driven
Turbo - Exhaust driven
SN95StangMan
1,292
Lynwood, CA
May 27, 2004
  • May 27, 2004
Heres some more detailed info on how they work.
http://www.howstuffworks.com/turbo.htm
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
