  • SN95 4.6L Mustang Tech
Suspension Install Question
  • Thread starter Thread starter racinmy99
  • Start date Start date Feb 5, 2007
racinmy99
  • Feb 5, 2007
I am finally going to order my suspension. So what is the question. I can not really afford both the springs and struts at this time, as I need new rubber too.
So is it that much easier to do them at the same time or just as easy to do them both seperatly, minus the cost of re-allignment.
I am going with the Bilstein HDs and the H&R Sports.
Thanks in advance
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Feb 5, 2007
  • Feb 5, 2007
do them together. nice combo btw. the struts are fairly easy, with a lift i can have the fronts done in about 30mins.
DTNODYA
831
  • Feb 5, 2007
Yeah ... You would probably want to install them both at the same time. Why not go ahead and order one or ther other and just let them sit until you get enough $ ... That's what I did whenver I bought my shocks/springs.
BUT if you were determined to do one first .. putting the springs on would be the best idea. That way, you can trash your stock shocks faster and have an excuse to buy the new ones
And also, springs require a little more work (not that it's very difficult) ... so springs would be first IMO (if you don't wait to install them together). Shocks are simple.
racinmy99
  • Feb 5, 2007
Actually the struts are shot to hell already. I am tired of my stang sittin in the driveway so as I need tires too I was going the strut first route cause they definatly are effecting tire wear. But I am just thinking of biting the bullet and ordering both. That way I only get under the thing once. Hell it is only 225 more.
R
RoadconeTuning
458
Upstate, SC
Feb 5, 2007
  • Feb 5, 2007
do it right the first time... get it all
racinmy99
  • Feb 5, 2007
I was just thinking also, I should not need c/c plates if I am just going H&R Sports...correct??
tomustang
Psychotic Member
3,434
McLean Hospital
Feb 5, 2007
  • Feb 5, 2007
not really
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Feb 5, 2007
  • Feb 5, 2007
you shouldnt need the plates, however it till make your alignment tech love you.
tomustang
Psychotic Member
3,434
McLean Hospital
Feb 5, 2007
  • Feb 5, 2007
pimp'
*my forum moral is fading
GDawg
1,469
Nevada
Feb 5, 2007
#10
  • Feb 5, 2007
  • #10
If your struts are already shot, get the Bilsteins first (~$600 for both struts and shocks) (I think Struts are around $400 and shocks are around $200) then get your H&Rs... Better to not have to do the install twice but do what money permits. Sports alone, I wouldn't think C/C plates but if you went for SuperSports, definitely go with the C/C plates. And only get the best you can afford in all situations.
See my sig for my total H&R SS, Bilsteins and MM C/C plates...
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Monday at 4:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14 minutes ago
DuluthFoxbody
D
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
