Sway Bar Endlinks
Fri Guy
435
259
83
I need to replace the front sway bar endlinks on my fox. Car is lowered on H&R Super Sport springs. Can I use stock style ones or need some for lowered cars? Any particular ones you guys would recommend?
I just went through this with my H&R Race Spring lowered fox. I ended up going with the MM shorter style "for lowered cars" endlinks. Seems to have worked well. My 'stock' (because they looked new but PO installed them so no idea what they were - but they were different lengths each side... :O_o:) were too long and pushing my sway bar out of parallel. From my understanding, as long as whatever length you use keeps the swaybar ends parallel to the control arm then you should be fine.
