t-5 info
  • Thread starter Thread starter grd777
  • Start date Start date Jul 23, 2009
G
grd777
  • Jul 23, 2009
have a rebuilt t-5 but do not knoe if it is for a v-8 or 4 cly .hou can i tell and can i use it for my 351 windsor
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jul 23, 2009
  • Jul 23, 2009
measure the input shaft snout.
0.59" is a 4-banger
0.668" is V8
90topdown
138
Philadelphia, PA
Jul 23, 2009
  • Jul 23, 2009
If there is a metal id tag on it -- what are the numbers on it??
Should be 1352 - xxx
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 23, 2009
  • Jul 23, 2009
The 4 cylinder T5's have a different size pilot shaft and a 3.97:1 first gear. Measure the pilot shaft and compare
your measurement to the chart. Put the trans in first gear and turn the input shaft, counting the turns as you go.
The 4 cylinder T5 will turn the input shaft almost 4 times for one turn of the output shaft.
The 4 cylinder T5 trans has a 3.97:1 first gear so, it will wind up very quickly. If you blink you will have hit the
redline in first gear before you know it. It also has a lower torque limit spec, 235 Ft/Lb, so it may break easier
than a V8 T5. The pilot shaft is smaller, so you will need a different pilot bearing.
The pilot bearing you need is for a Ford Ranger diesel from AutoZone part #14672.
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
J
T-5 trans in a Fiat
  • Jim Shipsky
  • Oct 18, 2025
  • Other Auto Tech
Other Auto Tech Oct 18, 2025
Mustang5L5
T
New Guy from Southeast Missouri
  • tcooke11
  • Jan 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 17, 2026
TomcatPC
