T5 disassembly question
  • Thread starter Thread starter 69Rcode_Mach1
  • Start date Start date Oct 29, 2004
69Rcode_Mach1
1,473
Salt Lake City, Utah
Oct 29, 2004
  • Oct 29, 2004
Hey guys I just bought my t5 but i can't seem to figure out how to get the rolling pin out of the shifter block so i can take the top plate off. Im planning a g-force t5 upgrade kit so i gotta crack into this thing. The shifter itself is off i just have to get this pin out, its hollow and cylindrical, anybody know any tricks?
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
Oct 29, 2004
  • Oct 29, 2004
Hammer and punch is all you need. You just need a punch that is smaller than the outside diameter of the shifter block hole.
Just put it on the pin and drive it out.
There are two more roll pins inside the tranny. One is on the shifter fork rail and the other will need to come out to remove the 5th gear shift fork.
Unbolt the tailhousing, drive out the pin and pull the tailhousing and shifter block off together. When you get it off, make sure you don't lose the ball, spring and the roll pin.
69Rcode_Mach1
1,473
Oct 29, 2004
  • Oct 29, 2004
Thanks now i have the shifter block off and everything marked and put away i just can't seem to get the top cover off still the metal rod that is attatched to the top of the shifter block is binding to something. Is that the shift forks? how do i get past this problem?
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
Oct 29, 2004
  • Oct 29, 2004
Once you have the tailhousing clear, unscrew the top cover.
To take it off, lift it up a bit and then move the cover over about 2" to the passenger side of the transmission and then lift it up and out of the way. What you put the cover back on, you need to install it just like that.
69Rcode_Mach1
1,473
Oct 29, 2004
  • Oct 29, 2004
wait a minute the whole tailhousing has to come off?
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
Oct 29, 2004
  • Oct 29, 2004
Yes, once you take the shifter block off, you need to take the tailhousing off.
The top cover comes out with that long shifter rail as part of the assembly
Have you downloaded the T-5 service manual???
http://www.ttcautomotive.com/English/media/pdfs_autogen/T-5_Service_Manual.pdf
69Rcode_Mach1
1,473
Oct 29, 2004
  • Oct 29, 2004
o okay thats what i was confused on. Will i run into any other problems or complications in trying to get the tailhousing off or will it just unbolt and just slide off?
86T-Top
553
Dublin, PA
Oct 29, 2004
  • Oct 29, 2004
Once you get the shifter block off and unbolt the tailshaft housing, the tailshaft housing should slide right off. Then you can take the top cover off.
It seems like you are going into this rebuild blind. I would take Mustang5L5's advice and download that service manual. It gets a little more complicated inside, but not that hard.
Mario
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
Oct 29, 2004
  • Oct 29, 2004
Unbolt and slide her off.
Are you swapping G-force internals in? It's not that tough to do but i would download the manual in the link i gave. It explains everything step by step.
But if you need any other help, just keep posting it here. I just wrapped up a T-5 two weeks ago so everything is still nice and fresh in my mind.
69Rcode_Mach1
1,473
Oct 31, 2004
#10
  • Oct 31, 2004
  • #10
Thanks a lot guys. That manual was a big help also it was just what i needed. Ill post later to tell what happens. Also any tricks to getting some of the super tight bolts out of the tailhousing? AND GOOGLE MAN YOU WILL DIE!
4dStang
Banned
Oct 23, 2002
718
Near St Louis, Missouri
Oct 31, 2004
#11
  • Oct 31, 2004
  • #11
I just bought a service manual! Where was this 2 days ago. Good luck guys!
O
Ocalafox
266
sunny central FL
Nov 1, 2004
#12
  • Nov 1, 2004
  • #12
Off topic but, if you change the style chooser at the bottom of the page to "the darkmoon" google butthead goes away.
vann
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 1, 2004
#13
  • Nov 1, 2004
  • #13
See http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550
You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
See http://www.ddperformance.com/index2.htm for parts
OR
http://www.hanlonmotorsports.com/
There is a video on how to rebuild your T5 or Tremec. If http://www.hanlonmotorsports.com/ are out of stock see http://cartapes.com. It costs less than $20, and is worth every penny of it.
You will also need a magnetic base and dial indicator to measure the endplay ($20-$40). See http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=1290.
The tricky part is that you will need some shims to adjust the endplay in the two shafts: the new bearings will change the clearance. There is no way of telling what it will be until you get to the point that it is time to measure and check the clearances. Halon has the individual shims if you can wait for them. If you can't afford the wait, the auto parts store can sell you some shim stock and you can make your own, or have a machine shop make them for you. The shim stock comes in brass (easy to cut) and steel, in varying thicknesses.
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
Nov 1, 2004
#14
  • Nov 1, 2004
  • #14
Put the closed end of a cresent wrench onthe bolt, then take another wrench and whack the end of it. That usually always breaks bolts loose.
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
