T5 Fluid
  • Thread starter Thread starter 50bomber
  • Start date Start date Jan 19, 2006
1 of 2 Next Last
50bomber
116
Galvatraz, TX
Jan 19, 2006
  • Jan 19, 2006
Help......help rest me easy at night....I put in Redline MTL fluid in my new T5, afterwards, I realized that instructions called for ATF, and the bottle said that although it does cover ATF viscosity range, you should use Redline ATF D4 when it calls for ATF . My tranny does shift a little stiff, am I killing it by not getting it properly lubed?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 19, 2006
  • Jan 19, 2006
Interesting question.... GM t-5's call for syncromesh and I believe that the GForce also does. Will it work, probalby. Will it work like it's supposed to, probably not.
I hate to say it, but I would drain and refill with the cheap ATF to flush out the wrong stuff and then refill with the expensive ATF. It will shift so much better that way.
J
jerryD
1,061
Gladstone, MO
Jan 19, 2006
  • Jan 19, 2006
i used ATF type F in my T5 when I had it in my car.
5.0 Nostalgia
904
CT
Jan 19, 2006
  • Jan 19, 2006
If it's not shifting right, change it.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jan 19, 2006
  • Jan 19, 2006
You're gunna totally mess up the torque converter and the clutches and bands in that new T-5!! Hurry and change it before the clutch fins blow!
dvs bullet
326
Ontario, Canada
Jan 19, 2006
  • Jan 19, 2006
from What I've heard it isn't good for the trans. the material on the synchro collars are only compatable with certain fluids, I'd do what srothfuss said
HISSIN50
34
129
Jan 19, 2006
  • Jan 19, 2006
People used to use MTL in T5's but when I called Redline, they said that D4 was just for this application (manual trannies requiring ATF). I had wanted to use MTL because I live in the desert and they were pretty against it. I use D4.
There are still some old school folks out there that run MTL. Some report initial rough shifting when ambient temps are cold.
I would change out the fluid - look at 30 bucks down the drain vs a trans. maybe you can save the MTL and toss it in another car or a friends car.
BTW, nicely done Nick.
Good luck.
50bomber
116
Galvatraz, TX
Jan 19, 2006
  • Jan 19, 2006
WTF, dude? . Now I call , the only thing AOD is good for is dead lift competition, I got a serious back strain and a possible hernia from moving that chunk of iron around. Unless of course, you are kidding, aren't you?
PS: My tranny shifts somewhat hard, much harded than I am used to in my friends' cars, I don't know if its the juice or just a brand new tranny.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jan 19, 2006
  • Jan 19, 2006
That's what I run in mine.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jan 20, 2006
#10
  • Jan 20, 2006
  • #10
1993SSP
1,194
Ky
Jan 20, 2006
#11
  • Jan 20, 2006
  • #11
Ive got GM syncromesh in my T5,,, Should it be fine???
50bomber
116
Galvatraz, TX
Jan 20, 2006
#12
  • Jan 20, 2006
  • #12
Man that Redline stuff is like $10 a quart, yikes... . How about Mobil1 synthetic ATF? Any good, its only like 5 bucks a quart.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jan 20, 2006
#13
  • Jan 20, 2006
  • #13
All synthetics are good for the transmission.
Saleen0679
876
24
49
Yakima, WA
Jan 20, 2006
#14
  • Jan 20, 2006
  • #14
I've run MTL in my car for over 15 years without much of a problem in the Nevada desert and wouldn't hesitate to use the stuff in a hotter climate or somewhere that it's warm most of the year, but when the temperature drops into the 40° range you're going to run into shifting problems.
I expect it's pretty cold this time of year where you're located and the fluid is causing the hard shifting and it's taking longer for everything to sync up. If you want to stick with Redline and run into a lot of cooler weather then go with the D4.
mytight95
2,605
Dothan,Al
Jan 20, 2006
#15
  • Jan 20, 2006
  • #15
what is the name of the fluid made for manuals that require ATF..... redline D4?
thanks
jason
HISSIN50
34
129
Jan 20, 2006
#16
  • Jan 20, 2006
  • #16
thanks
jason
Jason, that is what Redline recommends for WC T5's.
mytight95
2,605
Dothan,Al
Jan 20, 2006
#17
  • Jan 20, 2006
  • #17
gonna put some in.... my car has been a little hard to shift at higher rpms lately..... i think the clutch calbe etc. is why but if not i will give this stuff a try, that don't work i guess it is time for a rebuild
jason
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jan 20, 2006
#18
  • Jan 20, 2006
  • #18
If you are looking for the factory recommendation it is:
Dexron 3 / Mercron
This is the fluid you need to cross reference when you purchase... But like Hissin mentioned, Redline recommends Dexron 4 which superceeds Dexron 3.
Just so you know.
mytight95
2,605
Dothan,Al
Jan 20, 2006
#19
  • Jan 20, 2006
  • #19
thanks
jason
50bomber
116
Galvatraz, TX
Jan 20, 2006
#20
  • Jan 20, 2006
  • #20
I am in Houston, TX area, trust me, its plenty warm now like 60-70s.....perfect crusing weather
1 of 2 Next Last
P
Toploader To T5 Installation Issues
  • Paul Greilich
  • Jun 14, 2016
4K
1965 - 1973 Classic Mustangs -General/Talk- Jun 18, 2016
65ShelbyClone
9
  • Locked
Expired 94gt Bolt Ons Nj $1000
  • 95PGTTech
  • Dec 19, 2013
11K
SN95 Mustangs For Sale (1994-04) Dec 19, 2013
95PGTTech
9
T5 Overfill Mess. SOS
  • stolen86
  • Jun 17, 2010
5K
Fox 5.0 Mustang Tech Jun 18, 2010
stolen86
T5 Questions
  • TwoToneHatch
  • Oct 2, 2009
Fox 5.0 Mustang Tech Oct 5, 2009
ID89GT
M
What fluid are YOU using in your T5?
  • MYSTICSVT
  • Nov 27, 2007
3K
Fox 5.0 Mustang Tech Nov 28, 2007
PUNISHER RACING
