Tapping?!
  • Thread starter Thread starter ddt4436
  • Start date Start date Feb 17, 2010
D
ddt4436
70
  • Feb 17, 2010
I have a 1990 mustang gt with intake, pullies, headers. When I rev the engine or driving there is a faint tapping coming from under the vavle covers Im not sure which one? The tapping will disappear when I rev the car up but comes back at low rpms or on start up. The car runs srtong and don't smoke. Is this a bad lifter?
stangbang302
180
fort valley, ga
Feb 17, 2010
  • Feb 17, 2010
mine used to do that but that was because timing was advanced to much, what octane gas do you use? its always best to use highest octane if your timing is 10 and above.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Feb 17, 2010
  • Feb 17, 2010
Also consider an exhaust leak. Check your exhaust man. Gaskets
D
ddt4436
70
  • Feb 17, 2010
The timing is good but it's more like a mechanical tapping even at idle sometimes. I think I have a lifter not oiling up?
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Feb 18, 2010
  • Feb 18, 2010
I think you have an exhaust leak at one of your headers. I use to have the same tapping noise and i just knew it was coming from the valve covers but i when i check my header bolts they were very loose and one of my gaskets was burned out. So check that out first.
D
ddt4436
70
  • Feb 18, 2010
Yeah I know about the infamous header exhaust leaks.lol But I asure you that it sounds like a lifter or loose rocker arm. Has anyone had issues with a lifter that isn't oiling?
F
FoxGT87
5 Year Member
Aug 1, 2009
1,518
St.pete FL
Feb 18, 2010
  • Feb 18, 2010
i had a sound just recently, sounded like a tapping when the car was accelerating, got worse, got worse. found out it was a burned out gasket on my passenger side header.
tannerc91gt
2,967
234
Indiana
Feb 18, 2010
  • Feb 18, 2010
for $13 in gaskets, you could find out if its a gasket leak....
bentley429isBAC
922
188
84
CT
Feb 18, 2010
  • Feb 18, 2010
Sounds like a lifter or rocker's. Stock rockers or rollers?
M
mystic 96
24
ORL FLA
Feb 18, 2010
#10
  • Feb 18, 2010
  • #10
try the old fashion way...get a long screw driver and put it to each cover and listen for the noise....hopefully its on the right side...if so then take off the cover and rotate the motor to get the valves closed on each clyinder on check for play.......you never know,,,could b just a bad rocker ..bent pushrod,,or maybe just loose nut...
D
ddt4436
70
#11
  • Feb 22, 2010
  • #11
Yeah I definitely will do that today. Yeah I agree I believe it's a rocker or lifter but I will most likely replace them all. The rockers are stock.
5.0W/5.0
129
Carson Valley, NV
Feb 22, 2010
#12
  • Feb 22, 2010
  • #12
Like said before, start with the gaskets, then move on to the valvetrain. Most likely, it will be the cheapest part that fails first.
D
ddt4436
70
#13
  • Feb 23, 2010
  • #13
Thanks guys. The gaskets are new and all the bolts are tight. Replaced the lifters and problem is fixed. A bad lifter was the villian. The tinging is gone! )
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Stock TB - smoke test - leaking bad
  • R82148V
  • May 18, 2025
2K
Fox 5.0 Mustang Tech Jun 5, 2025
R82148V
