Taurus Fan Fuse?
  • Thread starter Thread starter flashback87
  • Start date Start date Jun 27, 2013
flashback87
345
Cleveland, OH
Jun 27, 2013
  • Jun 27, 2013
Hey guys, I have a Taurus fan running through a bosch 75 amp relay which I activate through a toggle switch. The problem is it will run fine for a few days but it will eventual blow the 30 amp inline fuse holder that runs from post 30 on the relay to the positive cable on the battery. I am only using the low speed wire from the Taurus fan because that cools my car just fine.
What do you think is causing my fuse to blow? it seems the 30 amp inline fuse is only 12 guage wire and all the diagrams I look at call for 10 guage wire from the relay to the power source. I have a larger maxi fuse holder with a 60 amp fuse that is 10 gauge wire. Should I be using that or is 60 amps to big?
what is odd is the fuse does not blow when I turn the fan on but when it has been running for a while. like I said it will work fine for a few days and then it will below.
Just in case, here is how I have it hooked up to relay.
#30 - 12 gauge wire and inline fuse to battery
#87 - 10 gauge wire from fan with green led light soldered in
#85 16 gauge wire to ground on body
#86 - 16 gauge to toggle switch.
Thanks!
flashback87
345
Cleveland, OH
Jun 29, 2013
  • Jun 29, 2013
well, I put my maxi fuse holder back in with a 40 maxi amp fuse and that one just blew. It actually blew faster than the 30 ampe inline fuse. Should I be using a bigger maxi fuse? I am only running the low speed.
Any help will be greatly appreciated.
Thanks!
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Jun 29, 2013
  • Jun 29, 2013
You should be running 10g wires on all connections. 16g is way to thin and is causing the fuse to pop.
flashback87
345
Cleveland, OH
Jun 29, 2013
  • Jun 29, 2013
I'm now running 10 gauge from the fan to relay. 10. Gauge from relay to maxi fuse to battery. I am running 18 gauge from toggle switch to relay and 18 gauge from relay to ground. From all the diagrams I have been seeing, 10 gauge wire is only used for the fan wiring and power source to the relay. The rest of the wires from the relay are a smaller gauge. Is this wrong?
Thanks!
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Jun 30, 2013
  • Jun 30, 2013
like I said, run 10g wire on all the connections. Also, I don't like using a relay and switch as that fan pulls enough amps to blow that 40 amp fuse on start up. That is why most people including myself use a variable speed controller that ramps up the fan. The other option is using a volvo relay setup.
Mustang5L5
Mod Dude
Feb 18, 2001
43,363
18,107
224
Massachusetts
Jun 30, 2013
  • Jun 30, 2013
He can use lighter wire on the power and ground leg that operates the solenoid portion of the relay. Only the two fan power legs need to be 10ga. The solenoid in the relay draws under an amp, so no need for heavy gauge wire there. 16ga is fine for terminal 85 and 86
The fuse that the factory used for these fans (Taurus, sn95, etc) is a 30A slow-blow maxi fuse. If you use a standard 30A fuse you'll blow this all the time. Using a slow-blow type fuse will allow a temp spike of more than rated amperage for a short period of time during startup. You def want the fuse to be e weakest link and not the wiring, so don't up the fuse amperage to fix this issue
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 1, 2013
  • Jul 1, 2013
Best advice you have gotten so far. Take it and run with it.
An electric motor has a large surge current when it starts up, so a slo-blow fuse is a necessity.
flashback87
345
Cleveland, OH
Jul 1, 2013
  • Jul 1, 2013
Thanks, would a 30 amp maxi fuse work or do I need to get a specific slow blow fuse? I found some exposed wire which I think was causing my fuses to blow but I want to make sure I have the right kind of fuse in. I have a 40 amp maxi now but I will go down to 30 maxi or slow blow?
Let me know.
Thanks.
Mustang5L5
Mod Dude
Feb 18, 2001
43,363
18,107
224
Massachusetts
Jul 1, 2013
  • Jul 1, 2013
I believe by design all Maxi-fuse are the slow-blow type. The standard blade fuses are fast blow.
Just googled fuse box layout for a 3.8 L Taurus and they use a 50A maxi-fuse. Seems high to me. I'd prob try a 30A or 40A fuse and carry some spares. You def want the fuse to be the weakest link.
Sent from my iPhone 4S using Tapatalk
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
  • dan50
  • Jul 18, 2026
dan50
  • brandyn200
  • Jun 20, 2026
AeroCoupe
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
