Testing Stangnets VAST KNOWLEDGE
  • Thread starter Thread starter sn94gt.
  • Start date Start date Apr 11, 2007
sn94gt.
Altoona,Pa.
Apr 11, 2007
  • Apr 11, 2007
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 11, 2007
  • Apr 11, 2007
So all your going to do is swap the cam? No head swap or intake swap or MAF or TB swap? IF nothing but the cam is going to be swapped then there will be minimal gains. It is hard to get air into the 302's. The cam won't help with that since the TB and intake are bottle necks. The heads without work don't flow all that well either.
sn94gt.
Altoona,Pa.
Apr 11, 2007
  • Apr 11, 2007
I do this as a step in the modifications i have listed in my sig.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 11, 2007
  • Apr 11, 2007
so your installing a e cam and you already have the afr 165's etc etc etc installed?
sn94gt.
Altoona,Pa.
Apr 11, 2007
  • Apr 11, 2007
E cam,1.6 rr,& 70mm tb is being installed at this time.
RYC CUKR
1,437
Orlando
Apr 11, 2007
  • Apr 11, 2007
Like blue is saying if you don't have the heads and intake then you will see minimal gains with the cam, RRs and TB. The lower intake 5.0 HO intake is the first bottleneck on the 5.0s. It doesn't matter how much everything under it flows if the intake won't support it.
Now if you already have the intake and heads then I would imagine you would see gains. If you don't have the heads and intake I would wait until you have them to install the cam. That way you can do it all in one project. Keep in mind that the stock 5.0 cam is a pretty decent stock cam and there are lots of guys going plenty fast NA with the stock cam. How much you will gain in hp, mph and lower ETs I couldn't make an educated guess at though.
D
Daggar
3,902
  • Apr 11, 2007
This is a "guess my weight" thread.
--moved to Talk section--
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
G
One for the books
  • gerstc
  • Sep 15, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 15, 2026
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
