  • SN95 4.6L Mustang Tech
the correct spark plug? part # please
  • Thread starter Thread starter fiveoho
  • Start date Start date Mar 6, 2010
fiveoho
1,958
TN
Mar 6, 2010
  • Mar 6, 2010
2000 GT . stock .
autolite or motorcraft? im looking for the exact plug that came in the car factory. im assuming motorcraft.
lots of different options. summit and my local autozone seem to have several different flavors of each. please help me with the following:
-correct part # & brand
-factory gap specs
-torque specs
thanks!
R
ran260gt
365
  • Mar 6, 2010
Motorcraft SP-493
You can order all 8 from American Muscle for 30 bucks !
fiveoho
1,958
TN
Mar 7, 2010
  • Mar 7, 2010
thanks man.
factory gap?
nancygrl
257
Mar 7, 2010
  • Mar 7, 2010
I changed out my plugs last week in my 99GT...... sparkplug gap .052 - .056, at least that is what it says on the tag under my hood. I checked each one before installing, but the gap was spot on.
Gap should be the same for your 2000GT....oh, yeah..torque specs 13 ft/lbs. $3.09 each, all 8 from advance auto for $24.72.
fiveoho
1,958
TN
Mar 8, 2010
  • Mar 8, 2010
thanks nancy!
did you use anti seize? ive heard mixed opinions about it.
nice lookin' car btw. i owned a chrome yellow 99 gt myself two summers ago. however, i like yours better. clean
nancygrl
257
Mar 8, 2010
  • Mar 8, 2010
No problem....Thanks, I couldn't pass it up. I got it just before Thanksgiving last yr. Nicest one I could find that wasn't beat up. Wish it was a manual instead of autmatic, but that can be remedied Yours is a nice red rocket too.
Umm, I saw mixed reviews on the anti-seize also. I changed mine as a matter of not knowing the maint. history about the previous owner and wanting to know where everything was for my own piece of mind.
All my plugs were tight and didn't see any anti-seize on them, so I didn't put any on the new ones. (plus I thought I had some but I didn't). Knowing the issue with the plugs, I'll keep an ear out for any ticking noises from here on out.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 8, 2010
  • Mar 8, 2010
Once you put antiseize on your plugs it gets on the head threads and there is no going back.
Consider it carefully and then make your decision... People are generally split even on if it should be used.
I use it very sparingly, and I use copper based.
Rickyll7
718
  • Mar 8, 2010
Why would you not want to use it?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 8, 2010
  • Mar 8, 2010
The reasons for not using IIRC it are generally:
-throws off torque wrench reading, makes it harder to torque properly
-can be problematic if it somehow gets in the chamber or on porcelain
-once in there is in there forever
Like I said I use it but people will criticize the use of it all day long while others will swear its the way to go...
Rickyll7
718
#10
  • Mar 8, 2010
  • #10
I've been using it for years with no problems yet. It sounds like there are a lot of people who don't use it with out issue as well, so I don't see what the big debate is all about.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 8, 2010
#11
  • Mar 8, 2010
  • #11
Do you use copper or nickel based anti-seize? I have always heard it is best to use copper...
Rickyll7
718
#12
  • Mar 8, 2010
  • #12
I don't know... I'll have to check.
This is what I use.
http://www.jegs.com/i/Permatex/775/81343/10002/-1?parentProductId=752342
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
  • dan50
  • Jul 18, 2026
dan50
Fox Spark plugs
  • Mattjhop23
  • Jul 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 14, 2025
Reddevil91
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
