Progress Thread Therapy Car--Front Suspension
90sickfox
I didn't really have an issue with the stink...
SN Certified Technician
Mar 2, 2015
4,623
3,901
183
41
2.5 inch exhaust should be able to be adjusted to clear everything under the car. That exhaust was built incorrectly. I've seen all types of issues with badly installed exhausts on Mustangs. Exhaust systems are one thing you can't cheap out on. Wish the previous owner would've done a better job.
  • Sponsors(?)
Olivethefet
Slap me as well as point and laugh
May 17, 2018
920
525
103
39
Enterprise AL
I got the axle back in place last night and I'm a little concerned. The new U-joints that I got are Moogs from Rock Auto. They fit the axle just fine, but they seem to have a lot of slop. I don't remember the axle being able to move around so much before I changed them. Currently I can move the axle as much as 0.25" on both ends in either direction. I took a couple of pics, but its kind of hard to see. Just know that I'm trying to show how far the axle will move up and down on the U-joint.
This might be normal. It's just that I would rather fix it now if I got the wrong part.
Olivethefet
May 17, 2018
920
525
103
39
Enterprise AL
These are the U-joints that I got.
The description doesn't say anything about it being a special part.
This is what LMR sales.
According to the specs the axial length of both joints is 3.62". Everything looks the same. If it makes a difference I have not greased the bearings yet. They came with grease in the caps, and I plan on greasing them before I put it on the ground. I just didn't think that would make that big of a difference. The snaps are sitting in the recesses for them in the axle and yokes.
Potomus Pete
254
85
38
55
Sarasota Florida
How come there are so many choices, or sizes of u - joints. The dont make it easy. I need em but dont want to open can o worms. Enjoy time with the car . When you get time paint small parts. Always harmless fun . I just looked mine up and came up with a different #---- Standard trans
90sickfox
Mar 2, 2015
4,623
3,901
183
41
That's the wrong u joint for sure. There's no doubt in that. You definitely want the ones you can grease with the fitting in the body.
Olivethefet
May 17, 2018
920
525
103
39
Enterprise AL
Went by O'Riley last night and picked up a new u-joint. I defiantly got the wrong part the first time. Appears I got u-joints for an automatic transmission from Rock Auto.
If anyone out there needs a set of u-joints for an auto just hit me up! I happen to have a set that I doubt I'll ever use.
Anyway here is a pic of the new and old. Correct joint on the left.
Reactions: 90sickfox and Rdub6
Olivethefet
May 17, 2018
920
525
103
39
Enterprise AL
Went back by O'Reilly's last night and grabbed another u-joint. Got them installed last night, and they are defiantly much better fitting than the last ones.
Got it back on the car.
I also picked up some lube for the axle. Oiled up the axle bearings and got the axles installed as well as the diff cover installed. I wanted to give the gasket material time to setup so I didn't put oil in it last night.
I'm hoping with a little luck I can have everything back together this weekend and have it driving next week. That would be nice!
Olivethefet
May 17, 2018
920
525
103
39
Enterprise AL
LOL. Yeah, it does make everything else look that much worse. At some point I'm going to have to go from one end to the other and clean and paint. I just want it on the ground so I can drive it for a bit.
