  • 1994 - 1995 Specific Tech
ticking
  • Thread starter Thread starter red1995gts
  • Start date Start date Jun 11, 2009
R
red1995gts
42
  • Jun 11, 2009
when my car warms up i get a ticking sound off and on at idle or lower rpms. not at high. it sounds like is coming from the thermostat area. would a bad thermostat make this noise??
C
cbarr300
746
goose creek, SC
Jun 11, 2009
  • Jun 11, 2009
nope
Could be an exhaust leak or some top-end noise, though
it helps to get a long screwdriver and put it up to your year. Use it like a stethoscope. Check around the headers and all around the valve covers. Where it's loud is where your noise is coming from.
good luck
R
red1995gts
42
  • Jun 11, 2009
i got the stethoscope and its really loud when i hold it on the water neck. i have a aftermarket polished neck. what could it be?
earleys94gt
1,223
Ashley, Ohio
Jun 11, 2009
  • Jun 11, 2009
Are you leaking any fluids?
Sounds like it might be the water pump...
R
red1995gts
42
  • Jun 11, 2009
its not leaking anything. its water pump is bad doesnt it drip through a weap hole?
earleys94gt
1,223
Ashley, Ohio
Jun 11, 2009
  • Jun 11, 2009
Yeah, if bad, the pump would leak through the weap hole. I was thinking maybe a bearing in the pump or something.
It could be an injector, a loose bolt on the exhaust, any number of things.
I guess, if you have the stock thermostat neck, put it back on and see if it goes away.
R
red1995gts
42
  • Jun 14, 2009
could it be air in the system. i tried burping it maybe i didnt get it all out?
R
Unidentified Ticking Noise
  • revised
  • Jul 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jul 11, 2026
MT94GT
M
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Fog horn sound
  • brandon4v
  • Jun 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 23, 2026
squeak93
