timing gears or timing chain?
  • Thread starter Thread starter pb_paulie_b
  • Start date Start date Jan 9, 2006
pb_paulie_b
894
Chaptico, Maryland
Jan 9, 2006
  • Jan 9, 2006
I'm sorry if someone asked this before. I did a search but nothing really came up. Whats better timing gears or a timing chain?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 9, 2006
  • Jan 9, 2006
Chain or belt drive! The slip on gear sets (although cool) put a lot of stress on the front bearing surfaces.
I had one before, it sounded like a supercharger and no one wanted to race me anymore.
89white50
440
central MA
Jan 9, 2006
  • Jan 9, 2006
i was thinking about buying gears as well. How does it put more stress on the front bearing surfaces? jw...
L
luckythirteen13
648
Anaheim, CA
Jan 9, 2006
  • Jan 9, 2006
this has been asked many times and every time, timing chain wins out
87'GTstang
1,025
  • Jan 9, 2006
The best really is an aftermarket timing belt with cog gear setup. Although definitely not as stout as a timing gear setup or to an extent, a double roller, it is the easiest on bearings because it acts as a harmonic device and absorbs vibrations.
Black1987Stang
1,422
Jersey Shore
Jan 9, 2006
  • Jan 9, 2006
Me too? I dont see how...Ive just heard they put more harshness on the valvetrain since like a chain absorbs some little vibrations and the gears dont. A plus on the gears is it spreads out the torque from the crank between the 2 gears, and also gears cant stretch like a chain can (especially with stiff valve springs and big cam). I have Edelbrock Accu-Drive timing gears that i got off another motor I had and they do sound pretty sick, and I seriously had about 6 kids think I had a supercharger but if I ever tear back down the motor Im going to slap a chain on it. The gears do sound cool but theyre really loud when you have your hood open and is pretty hard to find a ticking rocker or something over the noise of the gears. I just put mine on because I didnt have money for a new chain set and these were practically brand new from a motor I bought to use the heads off of. I dont no much about Belt drives, I dont see many people use them except for high hp applications. If i ever got a belt drive I would get a Jesel setup, Ive heard alot of good things about them and I could get a niice discount on one when I get back home.
87gtconv
ragtopman
2,595
Southern Calif
Jan 10, 2006
  • Jan 10, 2006
I woud go with a nice double roller chain unless racing is full time. Gears are very noisey.
87GTSnake
96
PA
Jan 10, 2006
  • Jan 10, 2006
I used this, it works just fine.
http://store.summitracing.com/default.asp?target=partdetail.asp&part=FMS%2DM%2D6268%2DB302&N=115+4294908331+4294908282+4294925008+4294892074&autoview=sku
87gtconv
ragtopman
2,595
Southern Calif
Jan 10, 2006
  • Jan 10, 2006
For $70 delivered I cant see skimping on this!
HISSIN50
34
129
Jan 10, 2006
#10
  • Jan 10, 2006
  • #10
You have just got to LOVE the sound of gears though (at least for me. ).
Dont forget to factor in machine work for the cam mating surface, if needed.
pb_paulie_b
894
Chaptico, Maryland
Jan 10, 2006
#11
  • Jan 10, 2006
  • #11
Money is not really a factor, I'm just to the point of needing one or the other. Ebay has some nice billet ones. I think I'm going the chain route. I don't want peeps thinking I have a supercharger even though I do. Thanks for the help guys
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Jan 10, 2006
#12
  • Jan 10, 2006
  • #12
Gear drive and dont turn back they sound badass.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jan 10, 2006
#13
  • Jan 10, 2006
  • #13
They do sound good... Boy do they sound good. But if you have to figure out an exhaust leak / lifter tick, you are screwed because they are very loud. I had one and loved it, but it sure made problem solving an issue.
The thought on added stress is that the gear set transfer's all of the crank harmonics into the cam. This harmonic is what causes the wear on the bearing surfaces. A chain instead can vibrate a little without transfering all of that energy.
mustangsally93
281
Omaha,NE
Jan 10, 2006
#14
  • Jan 10, 2006
  • #14
What about the pete jackson gear drive? That what I'm getting for around 220 .
JCVERT
43
Lynden
Jan 10, 2006
#15
  • Jan 10, 2006
  • #15
Yah I have gear drive in my new motor, but it has yet to be run, motor is not installed yet, I loooove gear drives , some people say you get sick of the noise but since its only a weekend driver I'm not worried.
89white50
440
central MA
Jan 10, 2006
#16
  • Jan 10, 2006
  • #16
so im guessing the quiet(er) set are still loud as hell? i love the sound, but if its going to scare away all the pray whats the fun in that?
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jan 10, 2006
#17
  • Jan 10, 2006
  • #17
I never ran the quite version.... The "normal" one was un-real! NO-ONE will want to race you.
ninety1gt
162
san antonio
Jan 10, 2006
#18
  • Jan 10, 2006
  • #18
anyone have a sound clip?????
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Jan 10, 2006
#19
  • Jan 10, 2006
  • #19
Whitch has more inertia?
Lol,I want to see how technical this can get...
It is true that the belt and to some degree the chain will absorb some vibration/harmonics,but a gear will always stay true with timing events.
But,if you all are wondering,we use a FRPP timing chain with the indexed crank gear.I think it was around $100 buck,and had the steel gears,double roller,and came with the heavy duty steel thrust plate!And its doing just fine with a solid roller and +8000rpm's.
IMO a belt just kinda scares me...(what if it broke?things happen...)
O
Timing guide
  • oilleak1000
  • Oct 10, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 10, 2026
oilleak1000
O
H
Aluminum timing chain guides ?
  • healy1963
  • May 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2026
healy1963
H
D
Negative Grounds for 2008 4.0L
  • deadbeat
  • May 13, 2026
2005 - 2014 Specific V6 Tech May 13, 2026
deadbeat
D
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
