  • 1994 - 1995 Specific Tech
Timing Issues...
  • Thread starter Thread starter Guero
  • Start date Start date Nov 9, 2007
Guero
2,148
Nov 9, 2007
  • Nov 9, 2007
Why does my timing retard when I set it at 14, then when I keep it at a steady 3000rpm it retards to like 0.......
HISSIN50
34
129
Nov 9, 2007
  • Nov 9, 2007
Oh man, didnt you have the same situation when you were EFI? I think so............
What sort of timing advancement do you have and how is it set up (vac advance and mech advance?). Also, do you use manifold or ported vac?
Are you sure you're lookin at the correct side of the zero mark when noting it's at 14?
Your car hates you brah.
Guero
2,148
Nov 9, 2007
  • Nov 9, 2007
I dont remember..... Theres nothing on the Distributer hooked up except for the MSD6...........The Vaccuum is hooked from the tree to the carb...and yes Im looking at the right side cuz I think it stops at -10 degrees... and the advance goes up to 30+
Guero
2,148
Nov 10, 2007
  • Nov 10, 2007
ttt
HISSIN50
34
129
Nov 10, 2007
  • Nov 10, 2007
So you only have mechanical advance [Little weights inside the dizzy]?
Are you really sure the magnetic pick-up wires are connnected properly to the box? If backwards, you'll not get any timing advance because you're sending the signal the wrong way.
Guero
2,148
Nov 10, 2007
  • Nov 10, 2007
Theres only one way it will go in...The timing does advance but goes back down and retartds.....
HISSIN50
34
129
Nov 10, 2007
  • Nov 10, 2007
Wait a minute brah. Did you have a box when you were EFI too (I think you might have for the nitrous). As you know, the multiple discharge box can confuse timing lights. Right at 3K is when the multiple sparks change IIRC. Could we be on the right track here?
Also, with the pick-up, IIRC you want it connected whichever way has the timing most retarded. I know you said it could only go one way but it was worth mentioning..............
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
