Progress Thread TKO-600?
KZGUNS
I can swing up to 11”
Jul 23, 2018
668
318
73
44
chardon, Ohio
As some of you know I am purchasing @a91what Eaton m112 he custom put together for the sbf. I figured I’d start a thread showing my progress getting everything ready. I’ll let the pics tell most of the story. I picked up a summit balancer and a trigger wheel and spacer from 64bit tuning. The spacer is cut to properly align the pulley. I discovered however that it’s designed for a stock style balancer and there was no provision on the summit balancer to holt Tge spacers centered. I took the spacer kit that came with the balancer and chucked it up in my lathe to cut it down. Once that was figured out I made a plate I’ll be building off of for the vr sensor, it’s in a rough state now but I’ll trim it down and clean it up before I’m done. Don’t mind the grungy engine and bay, I’ll be addressing that this winter when I pull the engine and repaint and clean up everything.
Reactions: General karthief
  • Sponsors(?)
stanglx2002
CT Material here
Mod Dude
Jul 7, 2005
1,355
988
154
Thank you for starting a thread on this as this kit is going to a good home. The more pictures the better on the assembly progress of this on your car.
Reactions: KZGUNS
KZGUNS
Jul 23, 2018
668
318
73
44
chardon, Ohio
i love pictures as they tell a better story than I can lol. Just have to remember to take em when I’m on roll and plowing through a project.
KZGUNS
Jul 23, 2018
668
318
73
44
chardon, Ohio
Little bit more progress despite my welding helmet trying to blind me. Made a mount for the sensor. It’s not sexy billet aluminum but it’ll work. I still need to slot the holes to gain some adjustability to better square it up to the tooth but it’s sitting at ~.025 gap right now but a bit crooked.
Reactions: 90sickfox
KZGUNS
Jul 23, 2018
668
318
73
44
chardon, Ohio
Oh and I scored this on eBay for $19. Most are for sale at $100. It’s a bronco/f150 crank pulley and it’s about 6.5” which is roughly a 1/2” bigger than stock. According to Steve that should be about ~10psi not sure if I can use it without meth injection but will have when I’m ready for that in the spring maybe.
Reactions: TOOLOW91
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,603
5,800
204
31
Hillsborough county
Is there any play in that sensor mount? can you make it move with slight effort? We dont want that thing moving when the engine is running.
Reactions: KZGUNS
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,603
5,800
204
31
Hillsborough county
AWESOME!!
I wonder who you bought this menagerie of JY stuff never meant to be bolted to a SBF from.... :cautious:
I guess i need to go ahead and compile those pictures into an album for you.
Reactions: KZGUNS
Thread starter Similar threads Forum Replies Date
F Drivetrain TKO 600 swap notes Fox 5.0 Mustang Tech 8
F Drivetrain TKO 600 Swap, but what else? Fox 5.0 Mustang Tech 0
3 Expired Tremec TKO 600 5 spd .64 O/D w/ bell housing Drivetrain Parts 4
D liberty gears tko 600 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
J 66 coupe TKO 600 trans tunnel modification 1965 - 1973 Classic Mustangs -General/Talk- 0
8 WTB/Trade Tko 600 Drivetrain Parts 0
J Drivetrain Tko 600 Install Help. Tunnel Clearance Issues Fox 5.0 Mustang Tech 12
T 65-66 Owners With Tko 500 Or 600 1965 - 1973 Classic Mustangs -General/Talk- 0
T SOLD Wtb: Tko 600 Other Classifieds 0
A5literMan Tko 500/600 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
smkshw Tremec Or Tko 600? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
stangboy Drivetrain Faceplated Tko 600? Fox 5.0 Mustang Tech 3
jetmech807 Drivetrain 3650 To Tko 600 Swap Questions...... SN95 4.6L Mustang Tech 13
F 89 Notch Doing The Tko 600 Swap Fox 5.0 Mustang Tech 6
Pops Fun Drivetrain TKO 600 What to do 1994 - 1995 Specific Tech 5
bigjstang Tko 600 Fox 5.0 Mustang Tech 0
KrazZ27 TKO 600 Questions... 1994 - 1995 Specific Tech 12
Codydubb Help Trans Experts TKO 600 tailshaft housing removal 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
M Tremec TKO 600 upgraded to 900hp! MMR Pro Trans 900 Drivetrain Parts 0
Kdubslugga Tremec TKO-600 at Summit in Tallmadge for 1500 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
HGFireHazard Clutch Fork and TKO 600 1994 - 1995 Specific Tech 8
J NEW. COMPLETE TKO 600 Setup Drivetrain Parts 2
Chrome_Rust WTB: TKO 600 or T56 Drivetrain Parts 0
emu12 tko 600 tranny SN95 4.6L Mustang Tech 0
1 AOD VS TKO-600 Classic Mustang Specific Tech 5
3 speedometer gear for 373s in a tremec tko 600 Fox 5.0 Mustang Tech 1
S TKO 600 Repair Fox 5.0 Mustang Tech 0
9 Anyone Have A MGW Shifter On Their TKO 600? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
C TKO 600 problem SVT Tech Forum 2
90_Red_LX tko 600 or t56 swap and whats involved? Fox 5.0 Mustang Tech 5
C 1990 Nitrous Stroker TKO-600 5-speed Fox Body Mustangs For Sale (1979-93) 0
FoxRod87 TKO 600 rebuild? 1996 - 2004 SN95 Mustang -General/Talk- 0
BLOWN347STROKER TKO 600 Trans help Fox 5.0 Mustang Tech 7
S Tremec TKO 600 & Modular Bellhousing for sale! Drivetrain Parts 2
S Tremec TKO 600 Transmission for sale Drivetrain Parts 4
blackstangt About to spend $51 on tko-600 fluid, any alternatives? Fox 5.0 Mustang Tech 14
9 TKO 600 Neutral Safety Switch Connector & Crossmember Question Fox 5.0 Mustang Tech 3
9 TKO 600 Parts List Fox 5.0 Mustang Tech 5
S clutch for tko 600 SN95 4.6L Mustang Tech 3
K tko 600 and rst twin clutch set up 1994 - 1995 Specific Tech 3
rdharper02 How to tell if it is a true TKO 600? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
L TKO 600 Install Fox 5.0 Mustang Tech 0
H 98 cobra tko 600 SN95 4.6L Mustang Tech 0
A Anyone have a TKO 5 or 600? 1996 - 2004 SN95 Mustang -General/Talk- 19
M TKO 600 problems.. Fox 5.0 Mustang Tech 4
J Tremec TKO 600 ??? Fox 5.0 Mustang Tech 11
9 AODE SWAP TO TKO-600 1994 - 1995 Specific Tech 0
Yobi1Kanobi TKO 600 stiff to shift 1994 - 1995 Specific Tech 9
Yobi1Kanobi TKO 600 an clutch cable cover 1994 - 1995 Specific Tech 5
94GTLaserRC AODE to TKO 600 Swap..Maybe? 1994 - 1995 Specific Tech 6
