Progress Thread TKO-600?
KZGUNS
I can swing up to 11”
Jul 23, 2018
670
319
73
44
chardon, Ohio
Everything is off to the machine shop. He said he’ll probably add .0001 or a little more for the boost I’m running. Michael’s racing engines has a great reputation up this way. He said he’ll probably be done in 3-4 weeks.
  • Hell Yeah!
Reactions: Davedacarpainter
  • Sponsors(?)
KZGUNS
Jul 23, 2018
670
319
73
44
chardon, Ohio
As i'm waiting for everything to get back from the machine shop I keep thinking I'm most likley gonna kill this t-5 if i launch it hard. So I'm considering looking for a TKO-600. Any thoughts on this or other transmissions in that price range?
revhead347
Just rub Vaseline all over
8,446
1,237
214
40
Acworth, GA
There's a bunch. Hanlon will know what you need. He will most likely recommend a TKO600. He can set one up for you and ship it. The 3650s are popular too.
Kurt
Reactions: KZGUNS
2000xp8
SN Certified Technician
Aug 8, 2003
6,971
1,072
194
NJ
The launch isn't really what i see killing T5's.
It's the hard gear changes where traction holds.
If the trans is currently good, don't break it or else all the value is gone.
Not too many real choices, it's a G force or astro in a stock case, tko or t56.
If i remember correctly 90sickfox just went through buying a trans and Hanlon had him at $4500 all in.
Rcdgl
125
37
38
68
Fwiw, I have a tko 600 in my 66 Chevelle, behind a mild 350. I love it, it made the car. Not much power but it will handle the big block one day.
Highly recommend one. I got mine from American Powertrain and highly recommend them.
Reactions: KZGUNS
HotFox
901
525
134
40
SE Michigan
Liberty Gears did my TKO600. They bought a brand new trans and face plated 2nd, 3rd and 4th. Also Cro treated the internals and case. I believe it was ~4800 about 4 years ago. Its been trouble free.
Reactions: KZGUNS
revhead347
8,446
1,237
214
40
Acworth, GA
Did you just get a stock tko? Looks like it’s be strong enough for my application.
It's not the strength so much as the shifting. I have a shift package from Hanlon for my 3550 (old TKO) which is fiber lined blocker rings, and brass fork pads that I installed myself. I'm not bragging, but I shift my car real fast. The weak point in the TKO600 is the thickness in the metal at the front of the transmission case. It tends to crack. There used to be something called a Swarr girdle, but they aren't made anymore. Liberty offers a comparable product I believe. I've never used either one, but I've cracked two cases. I've had my 3550 for 20 years now, and so far I have sheared an input shaft, broken the teeth off of 3rd gear, sheared the drive gear off the countershaft, and cracked 2 cases. I've gotten so good at taking it apart, I can swap all the parts into a new case in less than 4 hours without breaking a sweat.
There are some key advantages to the TKO over the old 3550. It comes with the 26 spline input shaft which is what you want. It's much stronger than the 10 spline shaft I sheared. The countershaft is one piece, so that doesn't break as easily. It also comes with the 31 spline output shaft as well. In 20 years, I have never broken a 28 spline output shaft. I even did a die penetrant on it to check for micro fractures, and it was fine. However, the 31 spline shaft is definitely better. My car is very heavy, and I launched it very hard on heavy clutches for a long time.
The classic SBF and the modular engines have the same bellhousing bolt pattern. Hell, both engines have the exact same rear main seal. Those 1000hp 3650s aren't cheap, and likely you are better off with a TKO600.
I've dealt with both Astro and Hanlon for many years now. Both great companies, but Bob Hanlon really knows what he is doing. I always recommend calling Hanlon and talking to either Linda or Bob. It's just the two of them, a family business, and they give you that level of individual service that works for a lot of people. Linda does most of the phone work, while Bob is building transmissions. He's going to sell you what you need, not what you don't, for the best price. If you want to drag race the car, he's probably going to recommend modifying a few things inside the transmission. He can build you a streetable manual transmission that will keep up with an auto on the track.
Kurt
Reactions: KZGUNS
2000xp8
Aug 8, 2003
6,971
1,072
194
NJ
Mine came from promotion powertrain years ago.
He always has answered all my questions.
It was a package that had something modified internally and a promotion shifter with tri ax handle.
Included everything needed.
It was a NIB second hand package with clutch, bell, cable, firewall adjuster, everything included needed to install.
With pricing today, i'd guess i stole it at $2000...
KZGUNS
Jul 23, 2018
670
319
73
44
chardon, Ohio
Wow lots of great information! Thanks guys!! I have some homework to do... I don’t think I’ll have the budget for a fully built tko but I also won’t be beating on it all the time. It’s mostly a street car with a few trips to the track. I’ll definitely hold off and see how funds look when the engine is done and spring is here so I got time.
90sickfox
I didn't really have an issue with the stink...
Mar 2, 2015
5,194
4,274
203
42
I'm ordering from Hanlon now. Around 4100 for everything I ncluding transmission modifications ( aluminum bell...not SFI ). About 2 weeks to have completed. Great folks. Bob and Linda are really easy people to deal with. They are legends and stay busy.
Reactions: KZGUNS
KZGUNS
Jul 23, 2018
670
319
73
44
chardon, Ohio
That's not a bad deal at all. I may be able to swing that when everything else is done. we'll see.
Reactions: 90sickfox
Thread starter Similar threads Forum Replies Date
F Drivetrain TKO 600 swap notes Fox 5.0 Mustang Tech 8
F Drivetrain TKO 600 Swap, but what else? Fox 5.0 Mustang Tech 0
3 Expired Tremec TKO 600 5 spd .64 O/D w/ bell housing Drivetrain Parts 4
D liberty gears tko 600 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
J 66 coupe TKO 600 trans tunnel modification 1965 - 1973 Classic Mustangs -General/Talk- 0
8 WTB/Trade Tko 600 Drivetrain Parts 0
J Drivetrain Tko 600 Install Help. Tunnel Clearance Issues Fox 5.0 Mustang Tech 12
T 65-66 Owners With Tko 500 Or 600 1965 - 1973 Classic Mustangs -General/Talk- 0
T SOLD Wtb: Tko 600 Other Classifieds 0
A5literMan Tko 500/600 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
smkshw Tremec Or Tko 600? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
stangboy Drivetrain Faceplated Tko 600? Fox 5.0 Mustang Tech 3
jetmech807 Drivetrain 3650 To Tko 600 Swap Questions...... SN95 4.6L Mustang Tech 13
F 89 Notch Doing The Tko 600 Swap Fox 5.0 Mustang Tech 6
Pops Fun Drivetrain TKO 600 What to do 1994 - 1995 Specific Tech 5
bigjstang Tko 600 Fox 5.0 Mustang Tech 0
KrazZ27 TKO 600 Questions... 1994 - 1995 Specific Tech 12
Codydubb Help Trans Experts TKO 600 tailshaft housing removal 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
M Tremec TKO 600 upgraded to 900hp! MMR Pro Trans 900 Drivetrain Parts 0
Kdubslugga Tremec TKO-600 at Summit in Tallmadge for 1500 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
HGFireHazard Clutch Fork and TKO 600 1994 - 1995 Specific Tech 8
J NEW. COMPLETE TKO 600 Setup Drivetrain Parts 2
Chrome_Rust WTB: TKO 600 or T56 Drivetrain Parts 0
emu12 tko 600 tranny SN95 4.6L Mustang Tech 0
1 AOD VS TKO-600 Classic Mustang Specific Tech 5
3 speedometer gear for 373s in a tremec tko 600 Fox 5.0 Mustang Tech 1
S TKO 600 Repair Fox 5.0 Mustang Tech 0
9 Anyone Have A MGW Shifter On Their TKO 600? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
C TKO 600 problem SVT Tech Forum 2
90_Red_LX tko 600 or t56 swap and whats involved? Fox 5.0 Mustang Tech 5
C 1990 Nitrous Stroker TKO-600 5-speed Fox Body Mustangs For Sale (1979-93) 0
FoxRod87 TKO 600 rebuild? 1996 - 2004 SN95 Mustang -General/Talk- 0
BLOWN347STROKER TKO 600 Trans help Fox 5.0 Mustang Tech 7
S Tremec TKO 600 & Modular Bellhousing for sale! Drivetrain Parts 2
S Tremec TKO 600 Transmission for sale Drivetrain Parts 4
blackstangt About to spend $51 on tko-600 fluid, any alternatives? Fox 5.0 Mustang Tech 14
9 TKO 600 Neutral Safety Switch Connector & Crossmember Question Fox 5.0 Mustang Tech 3
9 TKO 600 Parts List Fox 5.0 Mustang Tech 5
S clutch for tko 600 SN95 4.6L Mustang Tech 3
K tko 600 and rst twin clutch set up 1994 - 1995 Specific Tech 3
rdharper02 How to tell if it is a true TKO 600? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
L TKO 600 Install Fox 5.0 Mustang Tech 0
H 98 cobra tko 600 SN95 4.6L Mustang Tech 0
A Anyone have a TKO 5 or 600? 1996 - 2004 SN95 Mustang -General/Talk- 19
M TKO 600 problems.. Fox 5.0 Mustang Tech 4
J Tremec TKO 600 ??? Fox 5.0 Mustang Tech 11
9 AODE SWAP TO TKO-600 1994 - 1995 Specific Tech 0
Yobi1Kanobi TKO 600 stiff to shift 1994 - 1995 Specific Tech 9
Yobi1Kanobi TKO 600 an clutch cable cover 1994 - 1995 Specific Tech 5
94GTLaserRC AODE to TKO 600 Swap..Maybe? 1994 - 1995 Specific Tech 6
