Torque Box?
  • Thread starter Thread starter Boostin
  • Start date Start date Dec 31, 2004
Boostin
57
  • Dec 31, 2004
Does anyone know a website that sales a whole replacement torque box. Not just the reinforments but the whole thing. I want a pretty beefed up one to.
Joe P.
56
Syracuse
Dec 31, 2004
  • Dec 31, 2004
Wild Rides racecars sells the stang box, a complete new torque box set up. Looks like its pretty hardcore. Needs to be welded in.
http://www.wildridesracecars.com/newstuff.html
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Dec 31, 2004
  • Dec 31, 2004
That is for upper control arm mounts, not the torque boxes.
I am not familiar with a company that sells a whole new torque box, and I think it wouldrequire major, major work to do them if one did. There are lots of companies who make reinforcements however -- which might be a good start for repairing damaged ones???
Boostin
57
  • Jan 1, 2005
Well what do i do if my torque box is already cracked. Do i just weld it up and then put the reinforcements in?
5.0 Nostalgia
904
CT
Jan 1, 2005
  • Jan 1, 2005
Where is it cracked? You can probably find someone to weld it back. Make sure you find someone that is an experienced welder. It has to be precise to make the car drive properly.
Boostin
57
  • Jan 1, 2005
If you just weld it back its more than likely start cracking agian within a year. Thats why i asked if you weld it back and put the reinforcements in will it still crack.
5.0 Nostalgia
904
CT
Jan 1, 2005
  • Jan 1, 2005
Where is the crack? Is it by the bolts in the area where you would put the reinforcements or on the lip.
Mavrick
2,264
Collingwood, ON
Jan 1, 2005
  • Jan 1, 2005
A good weld will not just break within a year...
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jan 1, 2005
  • Jan 1, 2005
I would think you will be fine (depending on how back things are of course). I'm no engineer, but the 'reinforcements' to me actually look like they take the stress from the weak part of the box (outside part where there is no frame to suppose it) and put it back into the top where there is some frame for support. So it's like extending the strong frame part over to both sides of the control arm. This is just my opinion of couse.
Rick 91GT
Mustang Master
95
99
PA
Jan 1, 2005
#10
  • Jan 1, 2005
  • #10
We weld up the cracks and add our supports all the time, no issues at all. It just needs to be done properly, make sure the boxes are back in shape before it is welded, etc...
A good weld is very strong, otherwise your entire car would just fall apart.
hllon4whls
BANNED
2,567
Covington
Jan 1, 2005
#11
  • Jan 1, 2005
  • #11
The weld should be stronger than the metal around it if done properly. This amazes me when they braze 2 overlapping pieces together. Very very strong even at that low heat level.
D
Transceiver Ring
  • dtarang
  • Aug 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 22, 2026
dtarang
D
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
