Total Mechanical Advance on a 72 Q Code
  • Thread starter Thread starter likesoldjunk
  • Start date Start date Apr 6, 2006
likesoldjunk
296
Calgary Canada
Apr 6, 2006
  • Apr 6, 2006
I've been cleaning up a '72 Q-Code engine to put into my '72 Mach 1.
which was rebuilt and bored out .01, but is otherwise pretty much stock.
Rather than screw around with the points, I'm putting in a Duraspark
unit from a '74 Torino.
I had the new distributer all apart, and was going to re-curve it for
performance. Literature I have says that an engine of that compression
should have a total mechanical advance of ~38 degrees.
My confusion is that the '72 specs call for 6 degrees initial, and an
autopsy of the points distributer used a 10L gap in the reluctor arms.
so (10X2)+6 = 26 degees total mechanical advance
Doesn't seem like enough.... Any comments ?
PS, I'm not worrying about the Vacum advance for now.
67topless
203
Raleigh, NC
Apr 6, 2006
  • Apr 6, 2006
Check out this article on Ford Muscle:
http://www.fordmuscle.com/archives/2000/03/timing/
But the synopsis is the following:
..."The rule of thumb is that the higher the compression ratio, the less total timing it can handle before detonation, and also the higher octane rating it needs to control detonation. Low octane fuels ignite faster, thus require less timing advance. Conversely high octane fuel can handle slightly more advance. Dyno testing has shown that most small block Fords with 9:1 to 9.5:1 compression make peak HP with 38-42 degrees total advance. Engines with 9.5:1 - 10.5:1 run best with 35-38 degrees total, and above 11:1, should not go higher than 35 deg. total. When using power adders such as nitrous, super or turbo chargers, the timing should be advanced accordingly..."
likesoldjunk
296
Calgary Canada
Apr 6, 2006
  • Apr 6, 2006
Well... that supports my theory so far. The Specs say
that my engine started life at 8.6 to one, so it should
be ~38 to 40. Yet the factory setup (Assuming that
points distributer was the original)
68RCodeConv
345
Houston, TX
Apr 7, 2006
  • Apr 7, 2006
4V Clevelands like LOTS of initial advance and a very quick timing curve. I recommend something like 12-15 initial (if your starter can handle it) and 35-40 total. The advance should be all in by 3000 rpm.
likesoldjunk
296
Calgary Canada
Apr 7, 2006
  • Apr 7, 2006
That makes sense to me, but I'm just having trouble
lining that up with the original equipment, which would
be 6 initial, 26 total.
Could you count all that up against smog equipment ?
Total Timing Explained
  • MRaburn
  • Dec 3, 2022
  • Digital Self-tuning Forum
3K
Digital Self-tuning Forum Dec 5, 2022
General karthief
Total Timing Mystery 1969 Mustang 302
  • YadiStang
  • Jun 12, 2017
4K
1965 - 1973 Classic Mustangs -General/Talk- Jun 23, 2017
bartl
Have a vacuum advance question when timming.
  • Dougsters
  • Aug 6, 2011
Classic Mustang Specific Tech Aug 8, 2011
PoppyMod
Checking Total Mechanical Advanced Timing
  • 93gtmustang
  • Jul 29, 2007
8K
Fox 5.0 Mustang Tech Aug 6, 2007
93gtmustang
M
2011 V6 stang official release
  • master_V12
  • Nov 29, 2009
  • 2010 - 2014 Specific Tech
  • 2 3
12K
2010 - 2014 Specific Tech Dec 12, 2009
SS02
