TPS ?'s
  • Thread starter Thread starter riceater89-5.0
  • Start date Start date Jul 17, 2004
R
riceater89-5.0
55
kentucky
Jul 17, 2004
  • Jul 17, 2004
ive seen people talking about adjusting there TPS between .95 and .97, but i dont know how u people are checking it! are u checking it at the harness plugin? do u check the orange and black wires? i tried to check mine everywhere i thought i could get a reading, and nothing!! so what gives ('89-5.0)
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Jul 17, 2004
  • Jul 17, 2004
You need to make a little slit in the green wire going to the TPS and with a test light stick the + terminal in the slit and the - on an engine ground somewhere and you'll get your reading.
J
Js5ohLX
287
Ohio
Jul 17, 2004
  • Jul 17, 2004
You mean volt meter right? last time I checked test lights don't have a voltage reading, unless you can tell by how dim the light is? (just givin ya some $hit) lol
The Shape
2,224
East ARKANSAS Delta
Jul 17, 2004
  • Jul 17, 2004
I use a couple of straight pins. I stick one in each wire and use aligator clips to attatch my meter's probes to the pins.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 17, 2004
  • Jul 17, 2004
Check the voltage between the green and black wires on the tps plug. However, it's a myth that "adjusting" it accomplishes much of anything. The computer on your 89 samples the tps voltage each time you start the car, and establishes the reading it gets with the throttle closed at start up as your idle tps voltage setting. As long as it's between about 1.3V and .8V - it will work fine; and changing it won't accomplish anything. So unless you're replacing it, don't bother with it.
The Shape
2,224
East ARKANSAS Delta
Jul 17, 2004
  • Jul 17, 2004
I have wondered about that Michael, I have adjusted mine like I said in my post above. But last summer when my TPS died on me, I just put the new one on in the parts store parking lot and it runs fine. I have never checked or adjusted the new one. I do electronic repair work for a living so I spend all day using a multi-meter. I know for a fact that even top of the line multi-meters (we use fluke meters) have a tolerance level of plus or minus a few milivolts. So if you were to set your TPS to .98 and you then measured it with another meter it might read 1.01 volts. I do see where you could use an analog meter to check that your TPS is working properly by making sure the sweep is smooth though.
R
riceater89-5.0
55
kentucky
Jul 17, 2004
  • Jul 17, 2004
hey ummm.... can u say, like, maybe keep your car from starting by screwing with the wires?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 17, 2004
  • Jul 17, 2004
There's lots of wires under the hood - which ones have been screwed with?
R
riceater89-5.0
55
kentucky
Jul 18, 2004
  • Jul 18, 2004
nevr mind, fixed it, bought a new sensor, presiate it any way!!
M
mooktank
237
#10
  • Jul 18, 2004
  • #10
did you get that memo about the TPS reports?
stock88
125
upstate NY
Jul 18, 2004
#11
  • Jul 18, 2004
  • #11
No, but Lumberg wants you to work today!
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
I am Running the - Cranks OK, but No Start Checklist - Help Please
  • 89Foxxy
  • Jun 2, 2024
Fox 5.0 Mustang Tech Jun 2, 2024
General karthief
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
