Trick Flow Street Heat Intake, 75mm SN95 Elbow, BBK 94-95 65mm TB, TFS NX Plate Kit
Speeds8erM-1
1,240
Pensacola Florida
Trick Flow Street Heat 5.0 Intake Manifold SOLD!
Trick Flow 75mm Throttle Body Adapter Elbow for 94-95 SOLD!
Trick Flow TFS Nitrous Express 5.0 Plate Kit, fits between upper & lower intake on Trick Flow Street Heat/Street Burner & Track Heater Intake Manifolds. Has 10lb bottle, feed line, other lines, solenoids (looks like a big ICEMAN NX solenoid), plate, some jets. You will need a relay (if you want to run one, some dont, but it's RECOMMENDED!), an arming switch, a wot switch or activation button, and some bottle brackets of your choice.
This kit will keep you from having distribution problems on the 5.0 EFI long runner intakes that you can get from a nozzle setup! Much safer setup!
I got this in a trade, and have no use for it right now.
This kit is $676+ new, sell for $430 SHIPPED.
More info here
Trick Flow Specialties TFS-N5150 - Trick Flow® TFX? Nitrous Systems - Overview - SummitRacing.com
BBK 65mm SOLD!
