Tuning This weekend
  • Thread starter Thread starter Cobain03
  • Start date Start date Oct 4, 2005
Cobain03
996
Lexington, Ky
Oct 4, 2005
  • Oct 4, 2005
ok i was talkin to a friend with a 66 289 and i told him about my power situation, and he said my timing could be off causing lack of power.
with my mods, what should be a reccomended timing numbers?
68 Coop
104
Mesquite, NV
Oct 5, 2005
  • Oct 5, 2005
Initial timing should be around 8* or 10*, with full coming in by 3000rpm.
rbohm
6,698
550
204
tucson,az
Oct 6, 2005
  • Oct 6, 2005
i have always had good luck with 10 initial, and 36 total, all in by 3000 rpm. you can try as much as 14 initial but be ready to back off if you hear the motor detonating.
RGS0907
429
New Jersey
Oct 6, 2005
  • Oct 6, 2005
Did you check over your ignition system really well? All of the plugs are clean with strong spark? I would check for vacuum leaks as well
D
DJCarbine
392
  • Oct 6, 2005
I am the friend he was talking about, lol.
I told him that he should check his timing with a light, make sure the outer ring on the balancer didnt slip causing inaccurate timing by finding TDC. I was running an old balancer, and my timing was 25 degrees initial with NO detonation, just decreased performance. I put on a new balaner and found out that the outer ring slipped, and I re-timed it to 10btdc.
I also told him he should take his dizzy apart because its pretty simple, check the mechanical advance springs and see which advance arm it is on. On my dizzy the advance plates were gummed up and sticking, so that helped out a lot.
I also checked the vacuum advance unit for functionality, and installed a pertronix Flamethrower II pickup kit and coil, which I hightly recommend to everyone still using points, but doesnt want a full MSD ignition system.
I also suggested using a vacuum gauge to help set idle mixture settings on the holley 4160 style carb, and to verify the float levels and overall engine health.
Come on... taking apart and cleaning a distributor is fun!
Also of note, whoever put my dizzy together mixed up the 2 springs for the mechanical advance... one was too tight, the other was so loose it actually fell out.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 18, 2026
nickyb
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
