turn signal
  • Thread starter Thread starter rudy herrera
  • Start date Start date Jul 24, 2009
R
rudy herrera
110
Jul 24, 2009
  • Jul 24, 2009
today when i was driving to school i pu on my turn signal and all it did was light up but it didt blimk i checked for bad light bolds but ther good
so wat could it be
TechSteele
60
North Coast
Jul 24, 2009
  • Jul 24, 2009
You were right, it normally means a bad light bulb.
Did you look at the bulbs, or just turn them on to check them?
Some times the filaments are bad and work off and on.
I dont think the relay would be bad, but thats easy enough and cheap enough to replace.
R
rudy herrera
110
Jul 24, 2009
  • Jul 24, 2009
k i turn them on and cheked
when i get home i will take them of and check one by one
were is the relay located justa incase i have to try some thing else
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 24, 2009
  • Jul 24, 2009
If both R & L turn signals are inoperative, it is the flasher.
The flasher is not mounted on the front of the fuse panel. The flasher on the front of the fuse panel is a separate one for the hazard lights. It is in one of several places, depending on when your car was made. Some are behind the fuse panel on the back side, others are behind the radio and some are behind the glove box.
Other possible problem sources for the turn signal malfunction are the ignition switch, multifunction switch and the plastic shell that holds the turn signal wiring connector pins.
If only one side doesn't work, you have a bad bulb, corroded bulb socket, or bad wiring.
If the front & rear bulb lights up but doesn't flash on one side, the ground wire for the front bulb is bad. The front turn signal ground wires are connected to the upper radiator brace that runs from RH to LH in front of the radiator.
R
rudy herrera
110
Jul 24, 2009
  • Jul 24, 2009
well my mustang is a 1990
and how does a flasher look like
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jul 25, 2009
  • Jul 25, 2009
Should be behind the Glovebox, Blue in Color if it is still the Stock Flasher.
R
rudy herrera
110
Jul 25, 2009
  • Jul 25, 2009
thank you i fixed it
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
