  • 1994 - 1995 Specific Tech
vacum problem
  • Thread starter Thread starter smokin95vert
  • Start date Start date Mar 18, 2006
smokin95vert
53
Gettysburg,PA
Mar 18, 2006
  • Mar 18, 2006
Ok the problem i have is i found a little black cylinder looking think in the engine bay. And it has a vacum line going in the bottom of one side and it comes out the other. It is on the passenger side by the fire wall. And it has a plug in the top and goes in the harness. My question is what is this thing and do i need it. It is about 1 inch diameter and like 2 inch long and has black rubber around it. Thanks jay
dstanggt50
1,316
Woodinville, WA
Mar 18, 2006
  • Mar 18, 2006
It sounds like the evap canister, but I could be wrong, it's used for emmissions. I still have mine so I dont know what would happen if you got rid of it, I assume that if you don't have a smog pump or off road pipe, you might not need it.
smokin95vert
53
Gettysburg,PA
Mar 18, 2006
  • Mar 18, 2006
I did take off the smog pump maybe it connects to the pipe that goes to the h pipe. thanks jay
Zero Signal
2,633
Tucson, AZ
Mar 18, 2006
  • Mar 18, 2006
It's the evap canister purge solenoid. It vents gas vapor from the gas tank into the manifold. I would keep it if I were you. Unless you get a vented gas cap.
smokin95vert
53
Gettysburg,PA
Mar 18, 2006
  • Mar 18, 2006
Thanks man its been bugging me since i found it unhooked. thanks jay :SNSign:
95cobraguy
637
11
Concord, NC by way of LI, NY
Mar 18, 2006
  • Mar 18, 2006
i ditched that thing a long time ago.
smokin95vert
53
Gettysburg,PA
Mar 18, 2006
  • Mar 18, 2006
did you just vent to the air and unplug that thing. thanks jay
HISSIN50
34
129
Mar 18, 2006
  • Mar 18, 2006
I offer one item of caution. The EVAP system is closed as it comes from the factory. If you happen to park in a garage with a gas heater of some sort, a vented gas line and a pilot light dont go well together.
G
godstangit
187
Illinois
Mar 19, 2006
  • Mar 19, 2006
LOL good point, I would leave it alone, its tucked pretty much out of the way, I forgot to plug the connector on mine back in while messing around and it threw a code.
95cobraguy
637
11
Mar 19, 2006
#10
  • Mar 19, 2006
  • #10
i have all the emission functions turned off in the chip, i ditched the charcoal canister as well. i dont have any problems as far as engine light, fumes, etc.
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
C
Need Help identifying this small black box
  • Cholly2991
  • May 28, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
99SvtCobraTx
9
