Vacuum Question
  • Thread starter Thread starter Skoobie
  • Start date Start date Dec 8, 2004
  • 3
First Prev 2 of 3 Next Last
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
Dec 10, 2004
#21
  • Dec 10, 2004
  • #21
HAHA I knew something was fishy when I got the thing for $10
HISSIN50
34
129
Dec 10, 2004
#22
  • Dec 10, 2004
  • #22
Michael Yount said:
Skoobie - You'd think so, but here's how it actually works. There were only 10 E303 cams ever built. The original 10 purchasers used them for a month or two, and then they pull it out to replace it with something else. They sold the cam used to someone else who does the same thing. To date, thousands of people have been E cam users. And that's the true story of the E cam. Oh - there were only 10 original Crane PowerMax 2040 cam users too (same cam).
Michael, dont forget, as timely as it is, that the same 10 cams came with a free fruit cake. again, those same 10 cakes have been re-gifted time and time again.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 10, 2004
#23
  • Dec 10, 2004
  • #23
Glad to see you've all got a sense of humor about it (great on the fruit cakes JT - LOL!).
ExplodingGopher
517
The mistake on the lake (Ohio)
Dec 10, 2004
#24
  • Dec 10, 2004
  • #24
Muscleford said:
I have the "B" cam in a carbed Capri and I pull 14" hg at idle of around 950 rpm.
I idle at 850 and around 700 in gear.
ExplodingGopher
517
Dec 10, 2004
#25
  • Dec 10, 2004
  • #25
I idle at 850 and around 700 in gear... so mine is lower.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 10, 2004
#26
  • Dec 10, 2004
  • #26
But what does that have to do with fruit cake or the E cam?
P
p5.0ny
133
Arnold, MO
Dec 10, 2004
#27
  • Dec 10, 2004
  • #27
E cam here, vacuum at idle is 14 inches.
Idle speed in neutral is 850, AOD car, gear is 600-650ish
Vacuum reading taken off the brake booster.
Good luck.
What is your vacuum reading at idle when the engine is revved up? It should drop to 0. Does it start to sputter and backfire. Just want to make sure we are chasing a vacuum leak.
89rdgt
103
Washington
Dec 10, 2004
#28
  • Dec 10, 2004
  • #28
Here are a couple tips for finding vacuum leaks for what its worth.
First tip carb clean its your friend. Take a can of carb clean while your car is running and spray it in locations of suspected areas. If you hit a leak your cars idle will bump up. caution dont catch your car on fire
* note: aftermarket intakes tend to sound like vacuum leaks but are not this is normal.
Second tip: unpluge your maf and remove your intake tube from your maf to tb. Start your car getting it running at idle. Get a chunk of cardboard (bigger than your tb inlet.) cover the inlet of the TB with the cardboard if your car is still running with your TB covered up you have a leak. Use tip one to locate the leak. Also a stehscope (sp) is really handy too.
Another note on your pcv issue. You said a shop diag. a bad pcv. Many pcv are missed diaged because the metal screen is pluged (screen sits right under the pcv.) I highly recommend you atleast inspect the screen to see if its cloged. I always replace them in pairs. If the screen is pluged it will cause excessive crankcase pressure and could cause engine and seal damage. Good luck
Any questions send a pm
HISSIN50
34
129
Dec 10, 2004
#29
  • Dec 10, 2004
  • #29
if one puts the cake on top of the motor (to try to warm it up and make it edible) the idle, with that cam, will change.
Skoobie
May 25, 2003
655
Vancouver, WA
Dec 11, 2004
#30
  • Dec 11, 2004
  • #30
The screen is in good shape. I pulled it and cleaned it out when I pulled the upper intake. I'll try the carb cleaner trick tomarrow as long as Im not coughing up lung cookies (been sick since before thankgiving) As far as 'warming the cake so its edible'...if you EVER find a way to make Fruit Cake edible you will be the richest man on the planet...thats right up there with finding the cure for cancer
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 11, 2004
#31
  • Dec 11, 2004
  • #31
Consuming a lot of alcohol makes fruit cake edible.
HISSIN50
34
129
Dec 11, 2004
#32
  • Dec 11, 2004
  • #32
Skoobie
May 25, 2003
655
Vancouver, WA
Dec 12, 2004
#33
  • Dec 12, 2004
  • #33
Well this is frustrating. I tried the carb cleaner and it didnt seem to effect the idle. Tomarrow I'll try cramming the fruit cake into the TB and see what happens Meen while what else could I try? I sprayed the vac tree, around the upper intake, TB, and the PCV area. Did I miss anything? Another thing I noticed about the idle is that is seems to go in cycles. I was standing there waiting for it to warm up and I could hear it; it would go from a smooth lopey idle and slowly transition to a studdery idle and then back again. Cycle maybe took 10-20 seconds? Not sure on that. Does this mean anything?
J
jerry beach
2,671
Ocala,FL
Dec 12, 2004
#34
  • Dec 12, 2004
  • #34
My stock one does that when its cold. Only for a few minutes and if you stay at idle that long. Once warmed up its steady. Pull the codes as suggested by M. Yount, and you could try cleaning the TB out real good. Take it off the intake and clean the crap out of it. Its a major cause of idle surge, and practically free to try. I have the idle adjuster plate too, did nothing for me.
Skoobie
May 25, 2003
655
Vancouver, WA
Dec 12, 2004
#35
  • Dec 12, 2004
  • #35
Squirted nearly half a can of carb clean in the TB. Everything is nice and clean, including the Mass air sensor. I guess the next thing to try is the codes. Unfortunatly we only have Napa, Schucks, and Car Quest in town. I dont think anyone of those pulls codes for free
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 12, 2004
#36
  • Dec 12, 2004
  • #36
Skoobie - did you remove the IAB solenoid - and clean it, and the ports passages that feed air through it? It controls the idle air and it's clogging/gunk in there that causes problems sometimes.
Also, are you certain all of your vacuum hoses are in good shape? IF they're original, my experience is that they've usually begun to dry out and crack, and when you go messing with them (to work on the car) vacuum leaks often occur. Vacuum hose is pretty cheap to buy.
Skoobie
May 25, 2003
655
Vancouver, WA
Dec 12, 2004
#37
  • Dec 12, 2004
  • #37
Im not sure what the IAB is? Or what it may look like so no I have not cleaned it What I did do today is re-hook up the vacuum line that goes from the intake to the carbon canister (Had it blocked off) and Im running some fuel system cleaner to wash out any carbon build-up. So we'll see what happens. Got any pics of the IAB?
J
jerry beach
2,671
Ocala,FL
Dec 12, 2004
#38
  • Dec 12, 2004
  • #38
Its the cylinder shaped thing on the side of the throttle body. Its on the side that faces the front of the car. You should really consider some type of repair manual. Books are great!
HISSIN50
34
129
Dec 12, 2004
#39
  • Dec 12, 2004
  • #39
Jerry is right. here is a linkie with pics and a write up. good luck.
http://www.muscularmustangs.com/iac.html
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 12, 2004
#40
  • Dec 12, 2004
  • #40
1) Pop hood
2) Look at throttle body
3) Small cylinder 1" in diameter, 3" long mounted at a 45 degree angle with a computer connection plugged into it
  • 3
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
A
1991 5.0 - fires up every time, idles perfectly, but once it’s warm it won’t idle for more than 15 seconds
  • Jul 27, 2021
  • 2 3
9K
Fox 5.0 Mustang Tech May 21, 2022
Mindseye007
A
Engine 1990 Fox wont rev over 3500 RPMS
  • alex.sweitzer
  • Oct 27, 2020
  • 2 3
15K
Fox 5.0 Mustang Tech Mar 21, 2021
alex.sweitzer
A
M
New guy here from SE Pa
  • magnum517
  • Feb 23, 2020
  • The Welcome Wagon
The Welcome Wagon Mar 8, 2020
magnum517
M
R
Fox Closed PCV System, Dual Valve Catch Can
  • RTW0223
  • Dec 6, 2019
15K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 30, 2021
jay98
