valve cover gaskets
Compton_Rider
34
ok..so i replaced the valve cover gasket..but i didnt do it right since it smokes more now and alot more oil is burned..how do i do it?
do i use rtv, a gasket or both?, its really hard workin in the cramped space by the firewall..anyways to help this out?..how should i crank the bolts down to? i dont have a torque wrench..so right now there to the point where i couldnt move them much more
help would be great
What kind of gaskets did you replace them with?
I only use the metal/rubber gaskets avaible at the dealer - I think FelPro makes one too. With the metal/rubber composite, you simply clean both surfaces, and light grease the gasket so it slides and doesn't bind when being tightened; then you evenly snug the valve cover bolts down. If you're using cork or rubber gaskets - leaks can be caused by overtightening them. Get it too tight and it can buckle up between the bolts, or force the cork out of the seal area.
Yes. Get these gaskets and you will never have another leak. And they are reuseable too.
Go here to get them.http://secure.50resto.com/product1.cfm?SID=1&Product_ID=1701&Category_ID=789
i unno what its made of..im guessing cork..i think im gonna go out and try it again, but tightening even more even..its got the metal rings in the screw holes
its fel-pro, feels and looks like cork, got the metal in the screws..and i went to advanced auto..they gave it to me
