vapor lock?
  • Thread starter Thread starter skywalker
  • Start date Start date Aug 10, 2004
skywalker
733
Pensacola, FL
Aug 10, 2004
  • Aug 10, 2004
Okay, I thought I'd fixed this, but it just keeps coming back. When I start the car, it is fine...but after the engine gets good and warm, after 10-15 minutes of driving, i'll lose all power at thottle. If I sit in the driveway it is slower to rev.
Vapor lock maybe? It has no issues starting back up, it just has no power.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Aug 10, 2004
  • Aug 10, 2004
doesn't sound like vapor lock, with vapor lock you will run out of gas and die. Think you may have to look elsewhere.
Is the choke fully opening when hot?
O
Ozsum2
695
  • Aug 10, 2004
Worth is right. (That's 2 this week). Vapor lock will kill the engine until the air bubble is cooled. I have had 2 Mustangs get on top of Pikes Peak (14,110') with the temp gauge pegged out and no lock. My weed eater did vapor lock last week however. Took 15 minutes to restart it. Choke??????????? Yes, maybe. Worse case may be the thing is trying to lock up on you. How is the oil pressure?
J-Scratch
74
  • Aug 10, 2004
adjust your carb.
O
Ozsum2
695
  • Aug 10, 2004
J-Scratch said:
adjust your carb.
Sounds like the idle cuircut is fine. No other adjusment will help when accelerating. Maybe accelerator pump diaphram or vac. leak.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Aug 10, 2004
  • Aug 10, 2004
I'm on a roll
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
