  • 1994 - 1995 Specific Tech
Very unsettling engine behavior - Please help.
  • Thread starter Thread starter Nobody
  • Start date Start date Nov 15, 2005
N
Nobody
2,515
Kenmore, WA
Nov 15, 2005
  • Nov 15, 2005
Lately I have been getting an occasional hiccup from the engine while cruising at partial throttle.
Symptom:
When holding speed (between 20-35mph) at partial throttle, the car will sputter/lose pwer for a split second and then act totally normal again.
This morning I was holding speed at 30mph at around 2,000 rpm and the car started to sputter a lot and for as long as I held it at 2k. If i gave it more gas, it would act fine.
Can anyone give me some insight on this issue?
Thanks,
Gabe
BPA
159
S.F.
Nov 15, 2005
  • Nov 15, 2005
No dtc's set?
BlackVert
5,589
9
98
Bethesda, MD
Nov 15, 2005
  • Nov 15, 2005
does it behave the same when in cruise control?
N
Nobody
2,515
Kenmore, WA
Nov 15, 2005
  • Nov 15, 2005
Hmm... I haven't use sruise control for months. I am not sure. Last week I took the car on a three hour road trip and it was fine the whole way - but I didn't use the cruise.
N
Nobody
2,515
Kenmore, WA
Nov 15, 2005
  • Nov 15, 2005
BPA said:
No dtc's set?
Sorry, I don't know what that means.
BlackVert
5,589
9
98
Bethesda, MD
Nov 15, 2005
  • Nov 15, 2005
DTC = Diagnostic Trouble Code
3greenfords
25
Niceville Florida
Nov 15, 2005
  • Nov 15, 2005
I'm having the exact same problem with my 95 GT. However mine seems to be worse when it has been several days without driving the car. The more I drive it the less problem I have with it sputtering and cutting out. I almost feel it could be a battery/alternator problem in that when I keep the battery fully charged by driving it every day it works fine.
94-302-vert
1,947
NE CT
Nov 15, 2005
  • Nov 15, 2005
I had that problem in an old Dakota. It needed plug wires. It got so bad that it would actually die sometimes and just start itself again... Noone could figure it out and one day I changed the wires and that was all it took. After that I bought lifetime wires and replaced them every 6-8k miles...
dstanggt50
1,316
Woodinville, WA
Nov 15, 2005
  • Nov 15, 2005
I would chk for codes, do a tune up (plugs , wires, cap, rotor, fuel filter,) and maybe try cleaning the maf as well.
N
Nobody
2,515
Kenmore, WA
Nov 15, 2005
#10
  • Nov 15, 2005
  • #10
Well it's time to do a tune-up. I'll start there. I do'nt have a code reader so I wouldn't know. I'll have to take it to my friend's place to pull codes. I've been reading up on this and some people have had to go so far as to replace the entire distributor. I hope a tune up will fix it.
Thanks,
Gabe
BlackVert
5,589
9
98
Bethesda, MD
Nov 15, 2005
#11
  • Nov 15, 2005
  • #11
Thanks,
Gabe
replacing the dizzy is really to get to the pip sensor. the sensor itself is not very expensive, the hard thing there is getting the gear drive off and back on. but your symptom does not indicate a bad pip anyways, not until it just dies on the highway out of the blue.
N
Nobody
2,515
Kenmore, WA
Nov 16, 2005
#12
  • Nov 16, 2005
  • #12
Oh that's good to know! Thanks
BPA
159
S.F.
Nov 16, 2005
#13
  • Nov 16, 2005
  • #13
you can check for dtc's without a code reader. do a search and you will find the info
C
Help ‘03 Gt Code P1409 Odd Symptoms
  • Cooper032V
  • Dec 28, 2017
  • SN95 4.6L Mustang Tech
13K
SN95 4.6L Mustang Tech Oct 11, 2019
OneSick99GT
R
Engine 1992 Mustang Hesitation/Cutting-Out
  • RTW0223
  • May 2, 2018
14K
Fox 5.0 Mustang Tech May 26, 2025
J
Please Help With 77 Dodge Aspen With A9l, T5, 5.0l Swap. Starts Then Dies
  • Jalopychaser
  • Apr 26, 2017
3K
Fox 5.0 Mustang Tech Apr 27, 2017
a91what
A
Random Stalling At Stop Lights And When Idling
  • Adam_2006Tungsten Gray
  • Jul 19, 2014
  • 2005 - 2014 Specific V6 Tech
8K
2005 - 2014 Specific V6 Tech Jul 19, 2014
Carb And Timing Problems.
  • fords2live
  • Aug 7, 2013
2K
Fox 5.0 Mustang Tech Aug 11, 2013
vfast
