Volvo Problems
  • Thread starter Thread starter 95GTV8
  • Start date Start date Nov 5, 2006
95GTV8
386
Washington State
Nov 5, 2006
  • Nov 5, 2006
My friend has a 01 s60 T5, and she's very ill. I think the engine is hydro-locked. There was standing water on the streets and we had to get to downtown and all of these other cars were going through the water fine, but right when we were leaving the last bit of water his car bogged down, and now it won't start. When you turn the key the starter just clicks, almost like it doens't have enough power to turn over the engine, we tried pushstarting it like 6 times, and when you let slip the clutch out to grab the flywheel the car will NOT turn over, it just brakes to a halt. I'm wondering if anybody has any experience with hydro-lock? Thanks.
95GTV8
386
Washington State
Nov 5, 2006
  • Nov 5, 2006
anybody have any experience with hydrolock?
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Nov 5, 2006
  • Nov 5, 2006
Pull the plugs and crank it over to get water out. Water doesn't compress so if it got into the cylinders there may be some bent parts.
billison
I like tinted tail
2,607
1,094
184
stl
Nov 5, 2006
  • Nov 5, 2006
have you tried to just jump the car? unless the guy has ram air that's low to the ground, the water would have a hard time getting that high to hydrolock the car....
rd
3,316
63
109
Ocean Springs MS
Nov 5, 2006
  • Nov 5, 2006
Been there, done that.
Try pulling the sparkplugs and seeing if that will get it to turn over. If so, start it. Watch it for oil pressure, and if ok, warm it up and dry it out.
I would check for water in the oil before starting, and change it as soon as possible, even if none looks to be there.
rd
3,316
63
109
Ocean Springs MS
Nov 5, 2006
  • Nov 5, 2006
95GTV8
386
Washington State
Nov 6, 2006
  • Nov 6, 2006
Thanks, i'll have him try that.
Prime Lord
Crappy Default Title
2,137
199
114
Denver-ish
Nov 6, 2006
  • Nov 6, 2006
The most important thing I learned about hydrolocking an engine....if you even SUSPECT that it may be hydrolocked, DON'T TRY TO START IT! I learned that the hard way when my old Jeep threw a rod....through the oil pan.
It depends too on how hard you were on the gas when water got in. If you were just putting along at idle, you might be ok.
Pull the plugs and spray some WD-40 into the plug bores. WD-40 will float the water and make it easier to get out. And when you try to turn it over (with the plugs out) stand back. If there IS water in any of the cylinders, it'll shoot outa there like old faithfull.
G/L man, my mom did the same thing to her 96 Volvo V70 a few years ago, that the intake on those cars is just too low.
95GTV8
386
Washington State
Nov 6, 2006
  • Nov 6, 2006
Well, my friend got word from the stealership today and a rod was thrown.
89SaleenGT
32
#10
  • Nov 6, 2006
  • #10
Had a buddy that had a hydrolocked rabbit engine and the guys tried to push start the engine and bent two rods.
Best bet is like the others said; Do not try to crank the engine. Pull the plugs shoot the cylinders with WD 40 and crank by hand.
Sorry about the thrown rod.
A fellow Volvo owner.
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
