long story short, i blew up my 98 engine, and got another one out of a 01 gt, to basically have a whole pi engine, to boost later.. motor came out of a wrecked car.. i put it in rebuild my trans, get the flywheel machined, crank er up, runs good!! so the maiden voyage, it starts knocking, not like spark, but under a constant cruise, it sounds like its going to fly apart, if i get on it a little it goes away, then comes back around 5k rpm, thats all ive taken it.. so today i swapped out the chains, guides, tensioners, cam sprockets, crank sprockets, balancer, and lifters.. So i crank it up no knocking, runs for about 2-3 mins and over about 1200 rpm it will start to knock.. so im really pissed, so i went and banged on it, for about 40 miles, as the thing is still under warranty.. still nothing, seems to be actually running better, but the knock is still there!! so is it possible for a baffle to get knocked loose in the oil pan? the motor came out of a running 01 gt with a 4r70 which is now a 5 speed..
what could be some thing that would make it do this? I know the bearings are fine, as i looked it all over when i put in in the car.. and plus it would have come apart, and it still is pulling great oil pressure..
