What did I break?
  • Thread starter Thread starter OrLackThereof
  • Start date Start date Jan 6, 2004
O
OrLackThereof
560
Palm Bay, FL
Jan 6, 2004
  • Jan 6, 2004
So I was driving the car today and left the Tires Plus parking lot.. I decided to get on it a little for the mechanics that were watching me drive out. I tacked it up fairly good, probably hit the red, and then hit 2nd. Now the car has been driven HARDER than this and has been to the drag strip several times. It's been beaten to hell and back and never had anything go wrong. But this time....I hit 2nd gear and the car starts shaking real bad. Feels like a broken suspension component. I immediately drop out on the throttle and kick it straight to Overdrive. (The car is an auto by the way). As I tip in on the throttle, the car shakes more. It feels like a steady, rhythmic misfire on one cylinder. It shakes real bad. I pulled it over and let it idle and it started pouring blue smoke out of the tailpipes. I had to drive it home, which took about 30 minutes.. When I got it home, there was no smoke anymore, but I checked the oil and I see what looks like either sludge or particles of some kind on the bottom of the dipstick... I haven't dumped the oil yet to look for shavings, but.... The car will still run and idle just fine but it shakes real bad, and there's a slightly funny noise coming from the tailpipes but I can't put my fingers on what it is.
One person I talked to thinks it's a bearing but I doubt it. The motor only has MAYBE 10,000 miles. Another thinks I overrevved it, broke the crab plate and spun a lifter, which ate a cam lobe.
Like I said, I haven't changed my oil yet, and I havent had a chance to pull all my spark plugs and run a compression check on the cylinders... I'll do that whenever I can get my hands on a compression gauge.
What do you guys think? PRAY FOR ME...
NeQX
904
Infront Of You, NY
Jan 6, 2004
  • Jan 6, 2004
Damn bro, thats pretty bad, even worse then stangnets' hosting.
I would complain to people who put engine together if you had a shop do it, bring it to them immediatly.
It is most likely something bad in the bottom end, which is worst fear. Good Luck with it!
Rick 91GT
Mustang Master
95
99
PA
Jan 6, 2004
  • Jan 6, 2004
It could be a lot of things, just because the motor only has 10,000miles means nothings parts break....
Compression Test and Leak Down test will help, how was the oil pressure? I would not run it anymore, drain the oil look for particles, if you have or can get your hands on a oil filter cutter/splitter you can look inside of it for debris.
O
OrLackThereof
560
Palm Bay, FL
Jan 6, 2004
  • Jan 6, 2004
Even after driving around for 30 mins like that, the oil press. gauge, even though it's faulty and reads too low, never registered a pressure drop.
I'll be draining the oil probably tomorrow or the day after...and I'll see what I can't get to cut that filter open.
The parts for the motor were all purchased separately and the top-end was put on by the local Mustang shop guy. The bottom end was all together already...it's a factory replacement Ford 2 bolt 302 short block.
What confuses me is, yes I might have overrevved the motor slightly. BUT I've done it before...and it was BAD at the drag strip. I had the tach hitting 6300 rpms STEADY in 3rd gear. I just don't see why it didn't fail then and now it just died suddenly.
MadMatt5oh
441
St Paul, MN
Jan 6, 2004
  • Jan 6, 2004
Head Gasket is possible too, no?
MadMatt5oh
441
St Paul, MN
Jan 6, 2004
  • Jan 6, 2004
Head Gasket is possible too, no? But yes, bring it back to the shop where the work was done
MadMatt5oh
441
St Paul, MN
Jan 6, 2004
  • Jan 6, 2004
This new website setup suck my salty nuts
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
