what first
  • Thread starter Thread starter roworld
  • Start date Start date Feb 17, 2004
roworld
105
baltimore md
Feb 17, 2004
  • Feb 17, 2004
should I get a trick flow upper and lower intake or a fuel pump and fuel pressure regulator.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 17, 2004
  • Feb 17, 2004
What mods to you have?...
87gtconv
ragtopman
2,595
Southern Calif
Feb 17, 2004
  • Feb 17, 2004
Assuming everything is stock the intakes wont need a bigger fuel pump or require adjusted fuel pressure! I waited till mine got noisey and then I upgraded!
roworld
105
baltimore md
Feb 17, 2004
  • Feb 17, 2004
I've got headers, h pipe and flows
G
gt90stang
568
  • Feb 17, 2004
A K&N filter with air box resonator removed or CAI should be next and then a new lower (at least) and upper intake manifold will get you the most bang for your buck. Then a bigger MAF will help also. Gears can be done at anytime for extra SOP excitement (index the driveshaft both front and rear after gear swap)! And don't forget about pullies.
After this it gets more expensive.....cams, heads, RR, upgraded ignition system and injectors. More cooling will be needed also!
Good Luck, Don
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
