  • 1994 - 1995 Specific Tech
what is wrong!
  • Thread starter Thread starter 5literstang
  • Start date Start date May 7, 2004
5literstang
1,374
Clark, NJ
May 7, 2004
  • May 7, 2004
ok i had an oil leak probem, oil was leaking a bit and the car was smoking alot when i would get on it. i changed the PCV valve and put new valve cover gaskets on and the smoking stopped for a bit but oil was leaking but not as much, oil still leaks a little and the car smokes a little bit now, the PVC valve helped alot i think. but what else could be the problem? thanks
moneypit94
1,723
Macomb, IL
May 7, 2004
  • May 7, 2004
Where is it leaking? Sounds like a rear main seal to me...
302fordracer
738
Vancouver, WA
May 7, 2004
  • May 7, 2004
or are you 100% it is a leak and that the car isn't burning the oil.....I assume you have checked the exhaust no?
5literstang
1,374
Clark, NJ
May 7, 2004
  • May 7, 2004
the oil only seams to be on the driver side valve cover, nad it doesn't spill oil it's just on top of the valve cover adn around it. nad the car smokes when u get on it, if it's a rear main seal, how much is it to fix?
moneypit94
1,723
Macomb, IL
May 7, 2004
  • May 7, 2004
unfortunatly a rear main seal is a PITA. For a 5 dollar part its going to take probably 4+ hours in labor i would guess. You have to either take the engine out or you have to take the tranny out... I would say nothing less then 250 bucks, I could be way off on that though..
Is it burning oil on the inside or the outside of your exhaust?
Get under the car and see if you can any oil? Is it leaking onto the ground? You will be able to see oil under your car if its a rear main.
5literstang
1,374
Clark, NJ
May 7, 2004
  • May 7, 2004
well, my friend has a shop so me and him would just replace it wihtout any charge, sohow do i know that i def need a rear main seal?
moneypit94
1,723
Macomb, IL
May 7, 2004
  • May 7, 2004
You will have to get under your car and look. If you see oil at the bottom of back of the motor and on the bellhousing that is what it would be.
But as i asked before is it burning oil on the inside or outside of your exhaust?
5literstang
1,374
Clark, NJ
May 7, 2004
  • May 7, 2004
and if not, where couldn it be? the oil only seams to be on the driver side valve cover, and i know it's not a valve cover leak cuz i just replaced those, nad i did the PCV valve as well, any other suggestions? thanks
5literstang
1,374
Clark, NJ
May 8, 2004
  • May 8, 2004
any other suggestion??? if i canot fix this i am goin to get a newer mustang, i can't stand this! thanks
moneypit94
1,723
Macomb, IL
May 8, 2004
#10
  • May 8, 2004
  • #10
I would say do a compression test on it.. Maybe you got a bad piston ring or something
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
