What speedo gear?
  • Thread starter Thread starter 1993SSP
  • Start date Start date Oct 3, 2009
1993SSP
1,194
Ky
Oct 3, 2009
  • Oct 3, 2009
Can anyone tell me what speedo gear I need?? I am not sure on my tranny gear wether it is 7 ot 8 tooth. It is a T5Z FMS 5 speed. I have 285/40/17 tires on the rear and 3:27 gears. My speedo is way off, I can be on a 70 MPH road and when the speedo reads 70 I am passing other cars like they are sitting still.
skunk21
1,203
Taxachusetts
Oct 3, 2009
  • Oct 3, 2009
The T5Z and pretty much all after market T5's have a 7 tooth drive gear and you need a pink speedo gear (19 teeth).
http://www.fordracingparts.com/download/charts/129.pdf
83-95 Speedometer Driven Gear & Clip Kit, 19 Tooth. Manual Transmission at LRS - Same Day Shipping!
1993SSP
1,194
Ky
Oct 3, 2009
  • Oct 3, 2009
Thanks, I'll have to order one, I need a new throttle cable and clutch cable, the price on the throttle cable is insane!! $99.00, I about fell outta my chair!
I did the math with the conversion calculator and came up with 17.76, my 285/40 tire shows 776 revs per mile, I am guessing I should round up and go with a 18 tooth
LaserSVT
3,548
233
Oct 3, 2009
  • Oct 3, 2009
I can save ya $15-$20 on that. I have a pink 19T gear sitting on my desk. You can have it for free just PM me your address and I will throw it in an envelope on Monday with a few stamps and send it to ya.
Forgot what it came out of, pretty sure it was my 92. Its in perfect shape though with no wear.
LaserSVT
3,548
233
Oct 3, 2009
  • Oct 3, 2009
I dont have a 18 tooth, I have a 17 tooth. Well two of them actually. I can send a 17 and 19 if you think ya will use one.
1993SSP
1,194
Ky
Oct 3, 2009
  • Oct 3, 2009
Thanks Laser, I was just about to repost on my figuring and found the correct revs per mile on my tires instead of using a generic tire calculator, I do indeed need the pink gear.
LaserSVT
3,548
233
Oct 3, 2009
  • Oct 3, 2009
Check this out: Calculators
It showes 17.7 teeth. So a 17 tooth will read just a hair (1-2MPH) faster then you are going and a 19 tooth will be a few MPH under reading.
Ill just send ya both and you can try it out. What I did was use a portable GPS to confirm my speed. Barring that just have a friend in a new unmolested car get to 60MPH and tell you when they are at that speed so you can see how close you are.
I better send it from the post office to make sure I put enough postage on it.
1993SSP
1,194
Ky
Oct 3, 2009
  • Oct 3, 2009
From what I could dig up my tires have 800 revs per mile. I came up with 18.31, The 19 tooth will have me close enough, definitely be a whole lot better than 10 or 12 mph off.
I will do that with the GPS to confirm it. Once I get the gear installed.
LaserSVT
3,548
233
Oct 4, 2009
  • Oct 4, 2009
OK, I will mail it out Monday.
Pay it foreward.
1993SSP
1,194
Ky
Oct 4, 2009
#10
  • Oct 4, 2009
  • #10
Most definitely Laser. Had a friend call today needing some 2x4's to finish a porch for someome, he wanted to pay me for some I had, told him not to worry about it. I'm all about helping someone when I can.
Chrome_Rust
530
Findlay, Ohio
Oct 4, 2009
#11
  • Oct 4, 2009
  • #11
In these times "Pay it forward" is all some of us can do. It's good to see people helping others out!
thumbs up guys!!
oh.... btw...
In my car since I did the SN95 dash, I used the cluster from a 95GT. Since I am using the stock VSS for the speedo, will it be off if i get the correct driven gear for my T5? (i am going to run 255/40/17's and 3.73's and the current trans is a 4cyl T5, says I need a 21 tooth gear) thanks!
LaserSVT
3,548
233
Oct 4, 2009
#12
  • Oct 4, 2009
  • #12
21 tooth sounds right. I have a 21 tooth but I just paid $15 for it cause its for my 3.73s that are going in my Mark VIII
LaserSVT
3,548
233
Oct 5, 2009
#13
  • Oct 5, 2009
  • #13
I sent the gears out today, should have them before the weekend.
I still think the 17 will be the closest of the two.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Drivetrain Speedo gear ate itself
  • keel
  • Aug 15, 2024
Fox 5.0 Mustang Tech Aug 15, 2024
AeroCoupe
