plan on changing my gear oil and gasket, going fresh on everything, might as well... so i need to know what weight of synthetic gear oil, then what type of synthetic transmission fluid? And im going with a fresh shortblock and heads with valve job and port, but using same pistons/crank/rods. but new bearings and rings. What weight of synthetic oil should i run?
