  • 1994 - 1995 Specific Tech
what would cause???
  • Thread starter Thread starter MI95Cobra
  • Start date Start date Sep 27, 2007
MI95Cobra
451
Oklahoma City
Sep 27, 2007
  • Sep 27, 2007
what would cause my car to die when i turn my defroster on????
HISSIN50
34
129
Sep 27, 2007
  • Sep 27, 2007
Does the car stall with the AC on also? If so, the IAC might not be working properly.
94-302-vert
1,947
NE CT
Sep 27, 2007
  • Sep 27, 2007
The defroster is causing it to die... don't use it...
In all seriousness... I would try disconnecting the defroster from the window then see if it still happens... could be a shorted out defroster causing a high electrical load...
Is the fuse blowing?
Yellow302
789
NJ
Sep 27, 2007
  • Sep 27, 2007
turning on your AC/defrost adds a value to increase IAC to allow more air through due to the demand of the increased load on the engine. Try cleaning the IAC or you may want in give your TB screw a baby turn forward to increase your base idle a tad.
Or if you had a chip id just add more value to the IAC when the ac comes on.
MI95Cobra
451
Oklahoma City
Sep 27, 2007
  • Sep 27, 2007
ok....so check the IAC...is there a way to check it???
HISSIN50
34
129
Sep 27, 2007
  • Sep 27, 2007
You really need an oscilloscope to check it's function.
If you can view PIDs, you can get an idea of what is going on.
Otherwise, you might want to clean it. Here's a little article about doing it.
Good luck.
MI95Cobra
451
Oklahoma City
Sep 28, 2007
  • Sep 28, 2007
thanks hissin5.o....there was alot of carbon built up on the smaller one....i'll try it out when i go to work tonight....
MI95Cobra
451
Oklahoma City
Sep 30, 2007
  • Sep 30, 2007
ok...i was told to clean my mass air sensor also....so i cleaned it and noticed it was idling better and no surging.....when i was at a red light i turned on my ac and noticed my battery gauge dropped from half to about 1/4....is that normal??? or any ideas???
HISSIN50
34
129
Oct 1, 2007
  • Oct 1, 2007
That's not normal. When you turn on the AC, do the RPMs kick up?
If your idle drops too low, your alternator cannot keep up (you not only lower the alternator's speed [ergo output] but with the cooling fan, compressor and HVAC fan, you introduce a lot of electrical load).
Before the WCCT, I had to artificially raise my mechanical idle setting to help with a similar issue.
Good luck.
MI95Cobra
451
Oklahoma City
Oct 1, 2007
#10
  • Oct 1, 2007
  • #10
ok...should i increase my timing or open my throttle more???
HISSIN50
34
129
Oct 1, 2007
#11
  • Oct 1, 2007
  • #11
Personally I'd turn the idle up.
MI95Cobra
451
Oklahoma City
Oct 1, 2007
#12
  • Oct 1, 2007
  • #12
so you think it my be my new alternator????
toyman
1,944
54
79
Vernon BC
Oct 1, 2007
#13
  • Oct 1, 2007
  • #13
Quite possibility. Output voltage should be 14+v. If there is a local auto/marine electrical repair facility in your area they might best be able to help. They will have the ability to test and repair/rebuild the alternator as required. In my experience it's a better alternative than just replacing the unit
M
Progress Thread 96 GT Convertible when defrost turned on wants to kill it ..
  • mike7880
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 26, 2026
mike7880
M
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
WTB/Trade WTB AC components
  • LILCBRA
  • Aug 4, 2026
  • Mustang II Parts
Mustang II Parts Aug 4, 2026
LILCBRA
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
