whats the problem?
  • Thread starter Thread starter S.W.I 1
  • Start date Start date Mar 27, 2010
S.W.I 1
  • Mar 27, 2010
My 88 5.0 starts to smoke from the air vents when i drive it the faster i go the more smoke??
MustangLX-5.0
856
Lehigh Acres Fla.
Mar 27, 2010
  • Mar 27, 2010
Are you sure it's smoke? Where are you located? I though maybe you could be in the hot arizona sun and had your A/C on. If that were the case, its probably cold frosty air. Otherwise, if its not on, is the temp control set to the hot zone? Regardless if its on or not, if its set to the warm temp, anything burning on the exhaust pipes will get sucked up and pulled into the air ducts. You probably got oil or power steering fluid burning. Driving just forces the smoke back and thats why you get more at faster speeds. Try turning the temp knob to the cold position (leave fan off) . That should keep some of it out. In the meantime, find whats leaking and fix it.
393strokervert
340
florida
Mar 27, 2010
  • Mar 27, 2010
have you tried using Nicorette or Chantix? I've heard both have a good reputation.
MustangLX-5.0
856
Lehigh Acres Fla.
Mar 28, 2010
  • Mar 28, 2010
...... got weed
silverpony91
  • Mar 28, 2010
Bad heater core.............
7upstang91
936
124
74
Florida
Mar 28, 2010
  • Mar 28, 2010
Oil is probably burning off the headers.
I
Iowa rust
12
ierrrrrrra
Mar 28, 2010
  • Mar 28, 2010
X2 heater core
LocoSway
17
Anaheim, CA.
Mar 28, 2010
  • Mar 28, 2010
Does the window fog up on the passenger side? Also, does the air have a sweet smell to it, almost like maple syrup? If either of these then it's the heater core.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Mar 28, 2010
  • Mar 28, 2010
I believe this happened to my car years ago, if I remember correctly bypassing the heater core fixed it. =bad heater core.
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
  • Mindseye007
  • Aug 16, 2026
Mindseye007
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
