when is it time to fix door lock acuator
  • Thread starter Thread starter 89llx
  • Start date Start date Jul 13, 2010
89llx
5 Year Member
Aug 31, 2009
302
Jul 13, 2010
  • Jul 13, 2010
when I lock the door on my 89lx with a key it turns stiff, BUT when i unlock it with a key it turns easy, should i worry about it yet?
I just hate to tear off the door pannell and maybe never get it back right
thanks, 89llx
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jul 13, 2010
  • Jul 13, 2010
when it stops working
a word of caution tho, on a hatch that i flipped(not like rolled, bought cheap and sold), the actuator was junk and you could not lock or unlock the door period, i took the junk one out and just left it with no actuator, but if you were stuck for a few days without being able to lock the car it would definitly suck
89llx
5 Year Member
Aug 31, 2009
302
Jul 13, 2010
  • Jul 13, 2010
sometimes when it stops working the door will not open,,,that makes it hard to get the door pannell off
HISSIN50
34
129
Jul 13, 2010
  • Jul 13, 2010
What is the concern with removing the door panel? I'd replace it now since you seem to like using the key to lock the door.
89llx
5 Year Member
Aug 31, 2009
302
Jul 13, 2010
  • Jul 13, 2010
is it hard to get the panel back on right?
HISSIN50
34
129
Jul 13, 2010
  • Jul 13, 2010
I might be hesitant if the door panel has never been off ever. The vapor barrier would be pristine, etc. Otherwise if someone else has been in there before, I'd go for it. It's not tough but sometimes the trees are old and break.
twistedwankel
200
Spring Hill, FL
Jul 13, 2010
  • Jul 13, 2010
I could not lock the DSide door when I got my car but the pass side worked fine. I got a replacement cheap actuator (they didn't even send me a new rivet). I discovered I had to shear the aluminum rivet holding the motor on with a chisel (no problem) on the outside of the door. Removed the actuator easily then. Tested the new one and it worked twice and quit. Good thing I didn't buy a separate rivet!! I just left it off since I can lock my door just by pushing the button down and closing it and the passenger side still works off the power switch.
My 84 and 86 both have to be key opened anyhow so I never feel the need to fix it now. The passenger side would drive me nuts tho' and being convertibles I rarely lock them anyhow.
**Later I found a guy in our yellow pages who will come to my house and repair/replace any window or lock mechanizm for a modest price. He knows how to carefully remove all panels, water barriers and has the correct tools and parts to finish the job which he guarantees for 12 months. I won't be doing any of those inside door jobs again so long as he's still around.
89llx
5 Year Member
Aug 31, 2009
302
Jul 13, 2010
  • Jul 13, 2010
yes that is the problem the car has 60xxx miles and they have never been off
, so like i was saying when i lock it with a key its stiff, but when i unlock it with the key it unlocks easy, is it geting ready to screw up, or should i just leave the virgin panel alone?
thanks
89llx
5 Year Member
Aug 31, 2009
302
Jul 13, 2010
  • Jul 13, 2010
Im with you if i pull it apart screw the power locks i dont need them on a 2 door that i dont drive much at all
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 13, 2010
#10
  • Jul 13, 2010
  • #10
Don't waste your money on door lock actuators from some expensive Mustang specialty store. There is a better way...
Follow this link to fix your door lock actuator problems: Mustang Door Lock Actuator Retrofit
Lots of pictures and instuctions on how to do it...
Stuck with door lock actuators that don't work and don't want to pay the $50+ for a new one? Tried the junkyard ones and found that they last six months and freeze up?
A new actuator for less than $5. Fix one side for $18, do both sides for only $25. I don't sell parts, I don’t make any money off of the upgrade, I just tell you how to do it cheaply and easily.
Here’s a picture of the new actuator installed:
HISSIN50
34
129
Jul 13, 2010
#11
  • Jul 13, 2010
  • #11
If the car is really pristine, I'd leave it be till you have to deal with it then.
89llx
5 Year Member
Aug 31, 2009
302
Jul 14, 2010
#12
  • Jul 14, 2010
  • #12
This is what i think too,, I just hope that someday im NOT trying to take the door panel off with a door that wont open
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
  • Mindseye007
  • Aug 16, 2026
Mindseye007
H
Engine 1992 mustang LX starting issue
  • Hdbandit
  • May 25, 2025
Fox 5.0 Mustang Tech May 25, 2025
General karthief
