Which oil to use?
  • Thread starter Thread starter Crs
  • Start date Start date May 15, 2006
Crs
182
San Francisco, CA
May 15, 2006
  • May 15, 2006
I'm currently using Kendall 20w 50 and was wondering if i could run the "bottom end" dry with this weight. I have a stroked 351W that is 90 % street driven.
J
Jimmys66
419
Paw Paw MI
May 15, 2006
  • May 15, 2006
Running it dry is possible.... I quit running 20-50 because it takes so long to get it to the top end at start up. Most engine wear happens at start up when there is no oil protection. If it takes 1 second for a thin oil and 3 seconds for 20-50 well.....you can see where I'm going with this.
If you are using 20-50 for protecting the motor switch to a lighter weight synthetic or a semi-syn.
brianj5600
1,964
Middle TN
May 15, 2006
  • May 15, 2006
I would ask the engine builder. That sounds a little thick. There is HP in thinner oil since it is easier to pump. Some new engines run 0w20 to reduce power used to pump it.
Crs
182
San Francisco, CA
May 15, 2006
  • May 15, 2006
When i got my motor built 6 years ago, the guy that built it told me to run 20w-50 all the time. It's not a daily driver, but i dont know why he recommended that weight . I'm thinking of going to a 10w-40 Quaker State or Valvoline(Napa), and a Napa Oil Filter(made by Wix).
D
DJCarbine
392
  • May 15, 2006
I just recently switched from mobile 1 5w30 to kendall 10w30. Besides being dirt cheap(1.60 a quart), kendall seems to have a good reputation and 10w30 is a "safe" oil to run in most engines. 20w50 seems a bit high to me.
Cupid
162
  • May 15, 2006
20W50 is definitely high. I'm new to Mustangs, but out of all of my other classics, i've never ran anything that thick. Maybe if you lived in Nevada or Arizona. (extremely hot temperatures) I'd go with a 10W40.
LUCAFU1
496
Tucson
May 16, 2006
  • May 16, 2006
no way on anything but 10w30
with oil the farther the gap (10 and 30) the more polymers and less lubrication.
2nd Mustang
2,488
Southern California
May 16, 2006
  • May 16, 2006
I have used 20w-50 Castrol for several years in my Mustang. The PO said the engine was built by a marine speed shop. I recently learned that 20w-50 means the oil's viscosity is 20 weight all the time. The 50 just means it offers the protection of 50 weight when hot. My engine would blow smoke when it got hot and idled too long. I have since switched to straight 50 weight racing oil and although not cheap, it has reduced the smoking problem to almost nothing and my plugs are no longer wet. I haven't noticed any start up problems or any more drag than running 20w-50.
jcode68
892
Massachussetts
May 16, 2006
  • May 16, 2006
I am about to fire my CHP 347 long block for the first time, so I called them for reccomendation on oil. They told me 20/50, so that is what I am planning on running. I will be sure to prime the oil system just before I fire her up to make sure the top end is fully lubed.
TheEvII
162
Lakemoor Il.
May 16, 2006
#10
  • May 16, 2006
  • #10
I just switched to Shell Rotella T because since the oil companies have removed the minerals from the oil we have been wiping out flat tappet camshafts. We wiped out a cam in the 68 Stang we built and in a 66 GTO we built. I suggest you read this bulletin if you are running a flat tappet cam.
http://compcams.com/information/whatsnew/NewsDetails.asp?ListHistoryID=1985582846
Cannoball888
320
Gainesville, FL
May 16, 2006
#11
  • May 16, 2006
  • #11
Wow, I'm surprised no one uses Royal Purple, one of our sponsors. 10HP gain, is it BS?
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Hi from Western Washington
  • Bannister
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 31, 2026
keel
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
D
Resolved Oil pan welds cracking
  • D & D Racing
  • May 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 16, 2025
revhead347
