  • SN95 4.6L Mustang Tech
Which Plugs for my 03 GT
  • Thread starter Thread starter Burtonsnow157
  • Start date Start date Aug 25, 2008
Burtonsnow157
51
  • Aug 25, 2008
My car is at 41000 miles. Its not driven really really hard but i do get on it from time to time. My mods are in my sig (light mods) and im doing an oil change in a few days so i figured i might as well get a new pcv valve and spark plugs
first off, Should i skip the pcv. . . . skip the pcv and the plugs?
If its a good idea to replace the plugs, which ones should i get. I've done research and pretty much decided the motorcraft brand is best to go with but which ones should i pick up. . . dead stock ones or maybe a heat range lower with slightly tighter gap for a little better performance or something?
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 25, 2008
  • Aug 25, 2008
AGSF-32C's, no need to go to 22's for the mods you have unless you drive the piss out of it. Buy platinums instead of the C's if you want another 41k out of SP's tho.
G
GettinThere
553
Central Texas
Aug 25, 2008
  • Aug 25, 2008
From Randy, "if you want stock platinum heat range in a Motorcraft, it's a AGSF-32-PM which is now a SP-493, if you want the same heat range in a copper core, get a AGSF-32-C or SP-447"
You probably don't NEED to replace the plugs now, but it couldn't hurt (assuming you install them correctly). The coppers are a little better for performance, but you have to replace them about every 30k miles. You should replace the PCV valve every 30k miles.
Burtonsnow157
51
  • Aug 25, 2008
although the coppers have less longevity is it safe to assume that those are better than the platinums in our engines?
G
GettinThere
553
Central Texas
Aug 25, 2008
  • Aug 25, 2008
Yes, but not dramatically. You most likely won't feel any difference, assuming all of your plugs now are in good shape.
mtrsprt
  • Aug 25, 2008
TR-6's work great, and are cheap.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Aug 26, 2008
  • Aug 26, 2008
I would leave them alone!! Too many cases where they blew out on people and took the threads in the head with it. This guy at works daughter has 92K on her 99 GT and it still runs strong.
If you do change them, blow out the holes before you pull the plugs, and torque the plugs to 13ftlbs.
Burtonsnow157
51
  • Aug 26, 2008
yeah im gunna pick up a can of compressed air and try to wipe out the holes before i pull the plugs out.
also, i have a 1/2 inch drive clicker type torque wrench (its pretty big, and the lowest torque is 10 ft/lb). . . do you think i should pick up a 3/8 drive tq wrench to fit better and probably be a little more accurate since the range starts lower?
SVT32VDOHC
3,501
28
119
Motor City
Aug 26, 2008
  • Aug 26, 2008
Do NOT use 1/2" drive. Get a good Craftsman 3/8" drive wrench. Don't mess with Harbor Freight tools either, they are not accurate and you don't want to be off when it comes with 4.6L spark plugs.
Now....the truck 4.6L and 5.4L are the worst. My buddy called me today and just told me he changed plugs on his 5.4L F150 with 110K, on Saturday. He said he had no problems. I told him to call me if something happens because everytime I have talked to someone about tuning up a truck motor, they say don't do it, they always pop out.
Overall, just be carefull. Do not over torque them, that is the main reason for failure. I had to pull a couple 4.6L plugs from my 01 GT and when I put them back in with my fingers turning the extension...I let them get snug by hand, then put an 1/8 of a turn on them. I switched to the torque wrench and that was right at 13 ft lbs.
Burtonsnow157
51
#10
  • Aug 26, 2008
  • #10
The torque spec is 11ft/lb's for the plugs right, and 89 inch/lb for the c.o.p's?
i'm honestly not too worried about the job cause the way i look at it is, if i do everything right and torque them correctly, the ones in there do eventually have to come out . . . . if blow out in these motors is as common as they say, then you still have to face that problem now or later. . .
a blow out or any other problem is bad, and i'd obviously rather have that happen at like 100k than 40k but its technically all the same in the long run
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Aug 26, 2008
#11
  • Aug 26, 2008
  • #11
Yes. Copper is a better conductor of electricity only surpassed by silver. (yes there are silver spark plugs)
However, out ignition is COP and designed for copper plugs, so IMHO the difference in performance is negligilbe.
However, don't buy the Bosch "gimmick" plugs. Stock with OEM motorcraft plats.
You could go a little bit longer before doing plugs. I currently have 65K miles on my originals and i can lug 5th gear and not get a misfire at all still.
Been meaning to do them...just lazy. That's prob why i'm putting plats back in
Mustang225
424
Aug 26, 2008
#12
  • Aug 26, 2008
  • #12
I'm at 88k and still on OEM plugs and running strong.
2003 GT vert.
stangdrvr06
42
#13
  • Aug 26, 2008
  • #13
Just go with the oem recommended plugs. Take your time and make sure to torque them. I did mine a year ago. No problems at all.
SVT32VDOHC
3,501
28
119
Motor City
Aug 27, 2008
#14
  • Aug 27, 2008
  • #14
I have heard 11ft lbs too, but the Bullit Archives says 13ft lbs. I did mine at 13ft lbs and I'll knock on wood right now...haha.
R
Ryan441
173
wintersprings, fl
Aug 27, 2008
#15
  • Aug 27, 2008
  • #15
i was told not to run copper. that you'll foul them out really fast
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Aug 28, 2008
#16
  • Aug 28, 2008
  • #16
You won't foul them out, but their lifespan is not as long as plat so you'll replace them often
  • Gulftown980x
  • Jul 29, 2026
squeak93
  • Mindseye007
  • Aug 16, 2026
Mindseye007
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
