  • 1994 - 1995 Specific Tech
Wiring Question
  • Thread starter Thread starter NitroJas
  • Start date Start date Sep 15, 2005
N
NitroJas
27
  • Sep 15, 2005
I just got my electric water pump installed and now I am almost done wiring it in but have a question. I need to connect it to a switched on 12 volt source just wanted some suggestons on what to connect to. Would the radio be ok or should I connect directly to the ignition switch or is there something in the engine compartment I can connect to thanks for any help.
wildmandave
70
largo,FL
Sep 16, 2005
  • Sep 16, 2005
Don't hook it to the radio or you'll be popping fuses like crazy. You can either hook it to the ignition or run a relay and put it on a switch inside the car (optimal for drag racing because you can hook the fan and water pump to run and cool things down between passes).
wildmandave
70
largo,FL
Sep 16, 2005
  • Sep 16, 2005
By the way, where did you find an electric water pump for a 94 stang?
N
NitroJas
27
  • Sep 16, 2005
Meziere makes one specifically for 94-95 mustangs. I got mine off ebay for $400. I am runing a realy i just need a source to power the relay.
MisterCMK
20+ Year Stangneter
Oct 2, 2004
201
Fargo, ND
Sep 16, 2005
  • Sep 16, 2005
You could use the radio harness to energize the relay. Or, just use a DVOM and probe for something that is hot when the ignition is on. I can dig up some wiring diagrams on my service manual a little later tonight.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 16, 2005
  • Sep 16, 2005
Yeah, as long as you have a relay wired, and the actual source of the 12V is not from the ignition signal, you will be fine. those relays use less than an amp to click over.
I can't think of anything obvious in the engine compartment that's an ignition switched 12V signal. But on the main harness, I am sure one of those wires on the main harness would work. I wish there was a better way than probing each wire for 12V.
I would actually keep the relay inside the car, and only run the 12V main lead to the pump. Just ground the relay and the water pump on the body of the car somewhere. That limits the number of wires in your engine compartment, and it also keeps the relay away from the heat of the engine.
Scott
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
SN95 4.6L Mustang Tech Mar 23, 2026
