  • SN95 4.6L Mustang Tech
WTF did he do to my TC?!
  • Thread starter Thread starter VEE EIGHT
  • Start date Start date Jul 17, 2009
VEE EIGHT
85
Texas
Jul 17, 2009
  • Jul 17, 2009
I bought my GT a few months back and Im still slowly learning about some of the weird things the previous owner did to it. This is the second 99-04 GT I've owned.
Problem: The TC system is ALWAYS disabled, even after startup. In my previous 01 GT, the TC system would always turn on when you started the car (you have to turn it off every time you get in). However, in my new 02, its ALWAYS off and it wont turn back on.
WTF did this guy do to my TC?!
lazerred02
190
FT Stewart, GA
Jul 17, 2009
  • Jul 17, 2009
He either had a tuner and disabled it with that or they used to sell a product to disable the traction control for like $50.
Edit: I prefer mine to be off all the time anyways.
san~man
O-G
A little grass shack on a big lava rock
Jul 18, 2009
  • Jul 18, 2009
If it's always off, does the switch still enable it back "on?" If it does, the prior owner probably installed a "Trac Adapt" (or the like), which is a module which remembers the last setting prior to turning the car off.
Pull apart the radio trim, then remove the switch trim, and see if there's a black box sitting behind there. It should be labeled, and be about 4x2x1" or around that size.
four six
506
Hobart, IN
Jul 18, 2009
  • Jul 18, 2009
Edit:
SONIC02
70
  • Jul 18, 2009
If there is a trac- adapt box it should be located behind the gauge cluster.
But now that i think about it you should be able to turn it back on with the Tp button - the trac adapt just remembers the last setting pressed - so it looks like you have an issue with trac control or it was turned off with a tune.
Wolvrin704
120
Milford, OH
Jul 18, 2009
  • Jul 18, 2009
Sounds to me like its turned off with the tune, especially if you cannot turn it back on by pushing the button.
VEE EIGHT
85
Texas
Jul 18, 2009
  • Jul 18, 2009
I prefer it off, but you it'd be nice just knowing that I could turn it on if I wanted to. UGH.
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
